Advanced Engineering Tech For the more hardcore LS1TECH residents
853 heads or 862 on 5.3 MOST POWER
Old Nov 7, 2008 | 04:31 PM
thomascreation's Avatar
Default 853 heads or 862 on 5.3 MOST POWER
I have a 99 5.3 with an 02 zo6 cam along with z06 intake, 28lb injectors, true dual exhaust, cold air and a new bottom end. Currently the motor has the stock 5.3 862 heads. I have a set of 853's waiting to go.. My question is this, would I be better off milling the stock heads .030 to bump compression to 10:1 and porting them, or would I make more power milling the 863's to stock 5.3 compression of 9.5:1 along with porting. The main advantage to the 853's is the larger intake valve. 2.0
Old Nov 8, 2008 | 12:23 PM
any ideas?
Old Nov 8, 2008 | 12:26 PM
Elcaballoloco's Avatar
that is not an advanced engineering section kind of question.
