Advanced Engineering Tech For the more hardcore LS1TECH residents
Crank sensor output
Old Dec 26, 2008 | 10:27 PM
AKAFRED's Avatar
Default Crank sensor voltage output
is the crank sensor output 0,12 volts or 0,5v? looking around it seems that most state that its a 5v pulse but some state that its a 12v pulse.. has anyone actually scoped this and noted the voltage?
i did read a thread where someone used a volt meter on the cam sensor and stated that it was 12v for one rotation of the crank then 0v for the next..
thanks
Old Dec 27, 2008 | 08:01 AM
AKAFRED's Avatar
anyone??
Old Dec 27, 2008 | 10:13 AM
99345hp's Avatar
Im not positive, but i think it is a 5v squarewave signal. On monday I could look it up on my snap-on vantage and give you a definate answer.
