Advanced Engineering Tech For the more hardcore LS1TECH residents
Underdrive Pully???
Old Feb 17, 2009 | 04:01 PM
405HP_Z06's Avatar
Originally Posted by JonCR96Z
Or you could say that it's none of the pulleys that are causing this. One guy breaks 2 timing LS3 chains that happened to have a pulley. Sounds retarded to me.
Nope, one guy broke an LS3 timing chain and the other an LS3 and a double roller. Do a search for people that have broken timing chains and look at the common denominators. You can ignore it, but it won't make it go away.
As far as it being to small to control crankshaft harmonics, then what about the people who have pulleys along side lightweight flywheels or smaller converters. Especially those with built motors whose balance may be far worse than factory. They aren't breaking chains like that guy.
It may not have helped anything in that case, but it didn't cause it.
Torque converters and flywheels are not engine dampers and will not control 2nd, 3rd, and 4th order harmonics like the correct damper. The only component designed to dampen crankshaft harmonics is the crankshaft damper. An out of balance torque converter or flywheel with cause other vibrations in the engine damaging other components. Engine balance and harmonics control are two different aspects with a slight overlap.
The greater the inertia mass of any given damper, the greater its potential is for countering the torsional twisting or harmonic vibrations of the crankshaft.
A typical damper with an 8" diameter will almost always be more effective at reducing torsional twisting than a 6" damper, simply because the 8" damper has a greater inertia mass.
Reference: Fluidamper
Wheel to Wheel saw these problems repeatedly during development of the Motorola Cup cars. The solution was a timing chain damper and lower durometer rubber in the crankshaft damper.
Old Feb 17, 2009 | 04:02 PM
405HP_Z06's Avatar
Originally Posted by Bullitt347
So is this timing chain breaking issue only with the stock chain, or does it happen with a dual roller t-chain as well? Has anyone checked to see if this is happening only to higher milage stock chains, or does it not matter? Just curious......
Rob's 73 broke a stock single row and a double roller.
Old Feb 17, 2009 | 06:12 PM
LSwonderfull's Avatar
Remember as for cooling with underdriven pulley, most modded LS motors idle and spin at higher rpm than stock motors so waterpump rpm is brought back closer to OEM speeds with stock pulley. I agree smaller diameter balancer/pulley will not dampen vibration as effectively as larger unit, but other things weigh in like the proper interference fit with crankshaft snout. This can make or break the effectiveness of balancer. Engine balance and detonation can wreak havoc on a timing chain too. A aftermarket sprocket set may not have perfect line up gear to gear also. This will wear chain and load it excessively. How many do it your selfers here lay a straight edge on the two gears and than correct any difference? Food for thought.
Old Feb 17, 2009 | 06:56 PM
405HP_Z06's Avatar
As well as you can dwell on it, but that don't make it true. I agree that the correct balancer might have prolonged those chains, but saying that "replacing this -broken that" is plain stupid.
A broken timing chain and the ancillary damage caused by it DO make it true; it's a direct cause and effect relationship. Ignoring the facts is 'plain stupid'.
Old Feb 17, 2009 | 06:59 PM
405HP_Z06's Avatar
I agree, all of these can have an impact on timing chain life. From my experience, the crankshaft snout diameter is very close to identical across all of the cranks I've measured. I only use ATI dampers so I can only speak to the accuracy of their hubs and they are ALWAYS within press fit tolerance as specified.
Old Feb 17, 2009 | 08:21 PM
405HP_Z06's Avatar
It's a direct cause and effect 'assumption' for the most part. Not ignoring facts, as there aren't any to ignore. It may be as simple as installation error on the ones that could truely by UDP caused.
Though, I personally would give it a hard thought before installing a pulley on an LS3, it really isn't an issue for Gen III guys. Which is the issue here. And if you know of UDP related failures for LS1s, please post them.
There are plenty of examples here and on Corvette Forum, why don't you search. Not doing your own due diligence is ignoring the facts. There is a recent example on Corvette Forum of an ATI 25% under drive on a C5 Z06, so I would say it is a Gen III problem also.
Old Feb 17, 2009 | 08:54 PM
405HP_Z06's Avatar
Without searching, I'm sure it's just more theory on why it could go wrong. More often than not problems arise from bad installs. Can you guarantee there was no other problems with said chains and that the balancer was install correctly. No you can't.
I hear you on the LS3s, new product could have problems. But by the shear volume of UDPs sold for everything else. I say chances of having a problem are slim if it is the fault of the UDP.
So you have empirical data ASP 25% under drive 'pulleys' adequately dampen 2nd, 3rd, and 4th order harmonics on a Gen III engine?
I didn't think so......
Quantity sold does not validate quality and effectiveness.
lowaggie's Avatar
Think of it this way, on a M6 car, the 25% reduction would slow all the accessories down to the same speed as an A4. So I don't see any problems with it. And from what I remember of my heat transfer classes, the cooling system on most automobiles are designed to handle approximately 75% of the max power output for the engine. The only vehicles that are usually 100% or more are semi's. And that's only because they are constantly trying to make peak power to tow loads.
Old Feb 17, 2009 | 09:02 PM
Prerun4fun13's Avatar
You are stating no facts and arent contributing to the discussion on hand. Please get facts if your going to argue for the underdrive pully. I am not for or against the UDP at this point. I am just trying to get all the facts and info i can because i dont want to run into problems. And 10 hp to me isnt worth a possible broken timing chain.
Old Feb 17, 2009 | 09:04 PM
How would it spin the accesories 25% slower with an A4?
Old Feb 17, 2009 | 09:06 PM
That was another reason for concern is that when decreasing the size you are taking away its ability to dampen harmonics which would make sense in breaking a timing chain.
So lets here some more constructive conversation please..
Old Feb 17, 2009 | 09:21 PM
  #32
Spd-Kilz's Avatar
I started a similar thread in the Gen III External engine, but didn't get many enlightening responses. I'm subscribing to this thread to see other people's thoughts.
I'm with PreRun4Fun - a potential broken chain isn't worth 10hp.
Old Feb 17, 2009 | 09:24 PM
  #33
JonCR96Z's Avatar
So don't get it. Problem solved.
Old Feb 17, 2009 | 09:28 PM
  #34
Spd-Kilz's Avatar
That post was more useless than an LT1's cupholder.
Clearly, I'm aware of that solution. I'm trying to see if there is a causal relationship between an ASP pulley and a broken chain - and if there is one what the potential cause could be, so I can make an education decision whether I should buy a pulley, and if so, what to look for.
Old Feb 17, 2009 | 09:35 PM
  #35
JonCR96Z's Avatar
The answer you're gonna get in this thread is "ASP causes chains to break" and "I only use ATIs" and that's about it.
I have proof that my chains hasn't broken yet and I know other peoples chains that haven't broken from ASP pulleys. And I know that everytime one becomes available in the classifieds that it sells in minutes. Does that prove that it won't cause problems, no. But if they were that bad it wouldn't take long for everyone to know it.
I mean have you ever heard anything good about flowmasters on this board? Make a thread and see how many negative posts it gets. Then make on about ASP pulleys and see how many broke chain stories you get. It'll be the same one listed in this thread maybe another one, but I doubt that.
You might get lucky and you might not, but you're not gonna get a good answer to your question.
Old Feb 17, 2009 | 10:03 PM
  #36
405HP_Z06's Avatar
No one is stating facts. It's all theory.
Obviously you're not reading. Or you would know that 405hp is saying that the ATI is smaller and has better dampening capability.
Nope, not what I'm saying. 25% is too small whether it's an ASP or ATI. The max under drive I would recommend is 10%.
Old Feb 17, 2009 | 10:12 PM
  #37
JonCR96Z's Avatar
Just reiterating that your point isn't that smaller is necessarily worse.
Old Feb 17, 2009 | 10:38 PM
  #38
JonCR96Z
Read the post above it specifically states that a 8" damper will always be better than a 6" damper. So please tell me were he said that a smaller pulley is better for dampening? At this point your just post whoring and not contributing to the thread..
Old Feb 17, 2009 | 11:06 PM
  #39
^^^ ignore the post ***** back on topic please
Old Feb 17, 2009 | 11:59 PM
  #40
405HP_Z06's Avatar
Originally Posted by Prerun4fun13
Ok so I am going to be doing heads and cam on my 99 camaro Z28 M6 here pretty soon. I had a underdrive pully on my previous LS1 car and never had a problem. But I was giving it some thought and cant decide if the power gains is worth it or not. Basically my question is, Is it safe to be underdriving the water pump?? I am sure the GM engineers put alot of time and effort into making the water pump flow just right for the engine, and taking flow away could cause problems IMO. So lets here what you guys think..
Back on subject....
This is not just a water pump question, but a complete accessory drive question that's pretty complex. I built a spreadsheet to analyze pulley ratios for each component based on stock pulley measurements and aftermarket damper diameters.
When using a drive pulley with a different diameter all of the accessories are affected. Each accessory has specific requirements for pulley ratios to maintain acceptable accessory RPM minimums and maximums.
Here is a picture of what I have, let me know if you want it and I'll upload it. You can play with the numbers and see how your system works out. Keep in mind you will need some specific water pump flow information to accurately estimate the information your looking for. This is many months of research.
Here you go:
