Advanced Engineering Tech For the more hardcore LS1TECH residents
Straight-through muffler width vs. length: Which one makes it quieter?
Old Apr 18, 2009 | 09:54 PM
FastKat's Avatar
Default Straight-through muffler width vs. length: Which one makes it quieter?
Okay, so let's say you have a straight-through muffler like a Magnaflow, Borla, perforated glass pack, etc. Will you get more sound control by one that was wider or longer?
Let's say you have these two mufflers:
14" long and 6" wide
18" long and 4" wide
Which one would be quieter?
-Dave
Old Apr 18, 2009 | 10:11 PM
Jimmy P's Avatar
I had to make the same choice a few minutes ago, and ended up going with the Magnaflows. After having looked at both, it seems that the Magnaflow that has the the wider case and therefore more room for the glass packing will be quieter.
Although my choices where something like
16" long and 4.25" wide
14" long and 5" wide
Old Apr 19, 2009 | 09:36 AM
V6 Bird's Avatar
-Dave
The second one will be quieter.
Old Apr 19, 2009 | 11:06 AM
Grr's Avatar
Grr
length is quieter than width be a large margin
Old Apr 19, 2009 | 12:17 PM
TJ's Avatar
TJ
wouldnt you look at overall case volume?
seems to me the 18x4 would have more case volume to eat up the noise.
Old Apr 19, 2009 | 06:44 PM
V6 Bird's Avatar
You are looking at material packed around the center flow tubes. Narrow long cases will always have more packed around then a large case would. Ive always seen longer narrow mufflers quieter then short and wide ones...
Old Apr 19, 2009 | 08:58 PM
FastKat's Avatar
A 6x14 muffler has much more case volume than a 4x18.
I am buying the "longer muffler" argument Take each to the extreme:
Let's say you have a muffler that is 20" in diameter and 4" long vs. a muffler that is 3" in diameter and 30" long. Assume a 2" diameter tailpipe. It seems to me like the 30" long muffler would put the exhaust in contact with not just more packing material, but more effectively utilized packing material. On the 4" long muffler, the exhaust would only briefly come into contact with the packing material, and the material that's more than a few inches from the tailpipe would experience rapidly deminishing returns.
