Main bearing question ;)
btw, you should have the trans rebuilt to address the excessive endplay. otherwise you'll be doing the same thing 12k from meow.
This all started in October when I was driving to school. I was slowing down at a stop sign (engine at about 2000 rpm-ish) when all of the sudden *clunk* engine dies, car rolls to a stop. There was no loss of oil pressure or anything of the sort so I tried turning it over again and nothing. Locked solid... or so I thought.
So I got the car towed home and started searching for the problem. Interestingly enough when I got a pry bar and turned the engine over by hand I found that I could spin it with no problem what so ever about 80 degrees each way before I 'locked' up again. So at this point I figured I dropped a valve or broke the timing chain... nope, both fine. It wasn't until I pulled the engine out of the car completely and fought with the trans that I found this:
It appears that something in the trans locked up and completely destroyed my stall. Nice. I mean, don't get me wrong, I knew the damn thing wasn't going to last long but I didn't expect it to do that kind of damage. I guess a stock trans behind that motor lasting 12k miles with my less-than-kind right foot abusing it.
Well, having found the problem I bought a new TCI stall (cheap) and a built trans. I started putting the balancer (which i had taken off when I removed the front cover thinking I broke the timing chain) back on and noticed that I had about 1/16 of an inch of endplay. Lovely. And of course this was after I had already put the motor back in the car.
So, out it came again... this time on the engine stand. Pulled the oil pan, windage tray, got the thrust bearing out without removing anything other than the main cap holding it in (hoping to be able to replace the bearing and nothing else) and then realized that it had worn the crank some. So here I am. At this point I don't have the money to blow on a new rebuild so I'm going to pull the crank with the heads/rods/pistons still on/attached, take it in to my machine shop, have it fixed, new bearings, and back in. What a headache lol.
Sidenote: When my tuner was tuning my car he mentioned something about my line pressure being high in my transmission but didn't act like it was a big deal. Apparently it was lol. I still don't know exactly what caused all of this, but I will be watching it very carefully when (if) i get it running again.
When I was 18-19 and didn't have the money/tools/skill to repair a damaged engine, I swapped it with a $500 junkyard engine, and didn't so much as take the valvecovers off, I just put my cars accessories on (LT1 stuff, it was a Caprice) and drove it, and it ran fine until I decided to be a hot shot and rev it 1800 RPM higher with a different cam...and surprisingly enough it lasted like that for 10-15K miles too...then I blew it up and tried again with another junkyard engine, this time I replaced the oil pan gasket because it was SOAKING WET, didn't cam it, and it ran great for a couple years before I got rid of the car.
Again, not trying to be a dick, just trying to offer you some advice to get your car on the road and enjoyable rather than worrying about issues that you're really unsure of the direct cause, and wether or not they'll come back.
Welding and regrinding the thrust has absolutely no effect on the crankshaft balance. It is a very viable repair if done properly.
That being said, all of the major bearing manufacturers offer main bearing sets with wider thrusts. Your crank grinder should know about this. Unless the crank is really worn badly this is the easiest way to fix it, have it reground for the wider thrust bearing.
i stand corrected, i had always been under the impression when ever any repair to a crankshaft is done it must be rebalanced as an asembly so that it does throw engine balance off.
