Advanced Engineering Tech For the more hardcore LS1TECH residents
Fabricating an M6 Harness
Old Sep 9, 2009 | 01:05 PM
Rhin's Avatar
Default Fabricating an M6 Harness
So chances are that my 98 DD will be totaled out leaving me with my 95 Project (A4 to M6 conversion in process). I have the M6 harness from a 93 LT1 and the A4 Harness from an LS1.
Can i combine the two to create an appropriate M6 LS1 harness?
If not, where would I find a reasonably priced LS1 M6 harness?
My main concern is simply having a functioning speedometer and less about luxuries such as having the clutch remove cruise control, however that would be nice.
Thanks in advance for any feedback.
Old Sep 9, 2009 | 03:19 PM
bjamick's Avatar
Yes you can use your LS1 harness and it can be converted to an M6. Check out the trans section for which wires exactly are needed. You may have to move some pins to make everything work exactly right, but I converted my A4 harness to work with a t56.
Old Sep 10, 2009 | 02:48 PM
the_merv's Avatar
Veteran: Air Force
I converted mine aswell.. here is a thread for ya..
https://ls1tech.com/forums/lt1-lt4-m...onversion.html
Old Sep 10, 2009 | 02:52 PM
NemeSS's Avatar
u gotten pretty good at converting harnesses now huh?
