Dry decks.
http://www.turbomagazine.com/tech/02...gra/index.html
they say the engine is a dry deck. This got me thinking about the LS blocks and how hard people are pushing them these days. And would there be any advantage to designing a DRY BECK ls1 head and block package? you could still run water in the heads and block, but have them conected externally.
I know this is how engines used to be produced in the early 1940s and the early Merlin engines used in Spitfires and P51s used to run external water and oil lines.
Is there any disadvantages to this? Surely it would make for a MUCH stronger around the deck and would support the top of the liners better???? also lifting the heads wouldn't but such a masive problem....
What do you guys think????
Cheers
Chris.
i have been thinking about this for a long time, but my biggest concern are localised cooling hotspots
the norwood engine does not have that problem , as there is no coolant in the underblock at all
Cheers
Chris.
fyi-i have an ls block that has a 3/4'' thick deck for support of the liners,we do have coolant through the deck but in the form of small drilled holes instead of the huge cast holes
http://www.hotrod.com/techarticles/i..._v8/index.html
Do you see them being any advantage in running a dry deck? If someone could desing a system, that worked, would it be something you would be intrested in?
I was thinking more about the head sealing than anything else. be nice not to have to worry aboutpushing water at all. I know you guys have a system (dual o-ringing) that works REALLY well.
Cheers,
Chris.
Mate thats a very nice looking BBC!
I hear that Nelson Racing Eangines are looking at doing a 4 valve per cylinder head. they want to get one of their TT engine sreving reliably to 9000rpm.
Cheers,
Chris.
that being said, a dry deck block would be allot stronger and would allow you to upgrade to much thicker head studs to give more clamping force on the head to the block, but i do not see this working very well on a high hp street motor
that is a very nice looking BBC BTW
how about running an O-ring right the way around all the liners? with a receiver groove that should stop the head gasket from blowing out......
what would your concerns be for a street engine? would it be localised hot spots or something else?
Cheers
Chris.
this seems to be a better idea for NOT pushing water....than trying to run a block that would sacrifice the 2nd mortgage on the house
not my cup of tea, but interesting nonetheless
The idea of this setup is you dont have to worry about this. you will NEVER push water full stop. hopefully the head gasket will be stronger as there aren't holes cut in it! lol
On the cost i cant see it costing more than the RHS, Warhawk or LSX blocks. Bascially it would need to be designed into the casting. there would obviously have to be provisons for external water and oil ways again design into the block/heads.
Cheers
Chris.
And of course there is more than one way to skin a cat. But Maybe you missed the point of there is no reason to think in such a price bracket for JUST the street unless you have a huge budget to build from. You could use the Dart block (which not alot of people think about) and just like Burger King have it your way.
I think you missed a good point earlier in the thread about not pushing water because no water would be at the deck then, you would just blow head gaskets. Trading one for the other doesnt seem like a good idea. I would rather JUST blow a head gasket, but I have seen and we have built some pretty potent FI/nitrous engines that are run on the street every day out of most of the LS blocks, and they do not have a problem with pushing water or blowing head gaskets. The only thing they have problems with is affording new tires every 2 months.
It really comes down to how well the money is spent and the quality of the parts/work, not how much and the rarity of them. One of the sponsors on here build a turbo engine with the newer Callies C series compstar crank to about 800 HP. It is an inexpensive crank, so people think it is junk. I guess some people just WANT to spend more money regardless.
I wasn't trying to put down anyone or any company or the solutions they come up with. As i said above i think VA speeds Double O-ring setup works very well and has been tested to insane power levels. even more impresive when you realise they are using GM ally blocks! lol and there have been more than a handfull of people on here say that ally blocks wont hold 1000bhp let alown 1700bhp! lol
I dont think that many people would NEED this at the moment. and like you say if you are at the level where is is neded then maybe the DART block would be the best idea anyway! and it wouldn't be that big a chunk of the massive amount of money you would be investing.
Cheers,
Chris.
You appear to want something for the street, but then it seems you are more oriented towards wanting something akin to a high budget full on race build. You did not hurt my feelings, but it appears you are stuck on this notion and are dismissing some of the other things presented even though they will get you to the end you are persuing. The only things that are different are the means and ways.
At that level, pushing water or blowing head gaskets would be the least of your concerns. Paying the michelin man would be taxing enough. Or getting the vehicle certified to run at a track (safety).
There are alot of good suggestions that are more cost effective than looking at a (somewhat) exotic block like what you want. Obviously you want that though and there is no other way around it.
Keep us updated of the progress. Pictures are worth more than all the words you can type on a forum though.
All configurations have been tested over the years especially the IRL and F1, so not much is new from 2 & 3 o-rings to J- channels with nitrogen o-rings. I would say the pyramid rings would scare me as the sharp edge cutting into the head creates a stress point for the head to crack.
The impressive thing to me is Mike Brown running the NMCA/LSX real street with our block and doing the street cruise then 3 hot laps in a car that won the drag radial class running 7.4X's and has went 202 MPH on the same engine. That's quite a "street car" and water has to pass through or you would ruin the heads driving it that long.
I am not after building a dry deck engine! I know there are, at the moment, much cheaper and more effective ways to make massive power. Also I would NOT be prepared to put the time and money into R&D'ing something like this. I would much rather go for a 'off the shelf' combo that has been tried and tested time and time again.The whole point of this thread, and why it was posted in the advanced section, was to talk about the idea of dry decks and see what people thought of them. Obviously in VERY VERY high hp race applications they are useful and they do work. I was just trying to learn more about this method and about the downsides and understand 'IF' they could be adapted to work for the street.
Sorry for not putting this across very well. lol
Carl, thanks very much for sharing you knowledge. Do you think there could be a way of simply duplicating the internal water and oil ways but externally? Just thinking that that would still allow plenty of coolant to run through the head but you could keep the deck dry.... I think I have seen something like this in Skyline engines. They tap into the waterways to force the water to circulate around what would otherwise be hot spots.
I'll try and get some more info on how the early WW2 engines did it. Not sure if they where dry deck but they definitely had external water and oil ways.
Cheers,
Chris.
Proceed with your investigation.
. I thought the whole purpose of this thread was to cure your interest in it and because you were looking at one. That appeared to be your point. But as you can tell, the total outcome of the project is only reliant upon how much money you want to spend. And the idea of the dry deck is probably best associated with "race only". And not the average person's idea of it.I think of it like the same idea that people have when they buy the "race" pump from meziere when going with an elec water pump. It pumps less GPM than the street version for a reason. And I have seen them (the race version) perform way less than stellar on the street also. This confuses alot of people. But they should know, sometimes you need to draw a line between what an actual race car is and what a street car is that gets raced.
I guess the race guys have to do whatever it takes to get the power they want. Street, or even ameture racing, is alot diffrent and i fully understand that.
Cheers
Chris.
