Advanced Engineering Tech For the more hardcore LS1TECH residents
Fuel Injectors & Flow Matching, Static & Dynamic
Old Feb 5, 2010 | 03:50 PM
ZL1Killa's Avatar
Default Fuel Injectors & Flow Matching, Static & Dynamic
anyone see/read this before?
http://injectordynamics.com/
http://www.t1raceparts.com/en/produc...-injector.html
Info on Injectors:
""Dynamic Injector Flow Testing
Simply stated, a fuel injector is a dynamic device. It does not operate in a wide open or "static" condition. To learn anything of value about a fuel injector, it must be tested dynamically.
It must also be tested in an environment that simulates real world conditions as closely as possible. This means testing with gasoline, methanol, E85 or whatever fluid will actually be used on the running engine. It is also important that the injectors are tested at elevated temperatures because the electrical characteristics of the injectors are temperature dependent.
Injector Dynamics fuel injectors are the result of batch testing large quantities of specially modified fuel injectors, and then carefully matching them into sets based on their dynamic flow across the pulsewidth range. The result is vastly superior cylinder to cylinder consistency, even at very low pulsewidths.
In addition to receiving tightly matched injectors, you will be provided with dead time compensation values from 45 to 100 psi, and 8 to 16 volts. This data will insure that all the compensations in your ECU work properly, and your air fuel ratios will remain consistent as atmospheric or voltage conditions change.
Old Feb 7, 2010 | 06:27 PM
ZL1Killa's Avatar
i guess not....
Old Feb 9, 2010 | 09:59 PM
ZL1Killa's Avatar
not a single person up here has heard of any of these people?
Old Feb 12, 2010 | 08:25 AM
Old Geezer's Avatar
Yep. Part of Paul Yaw's operation in Phoenix, AZ.
They have some spohisticated testing equipment.
Old Feb 12, 2010 | 10:25 AM
ZL1Killa's Avatar
YES finally!!! I randomly googled some injector info and found them. I bought the ID725 injectors as I spoke with Paul, and then a few guys from T1 Race Development
