Advanced Engineering Tech For the more hardcore LS1TECH residents
Hall sensor
Old Mar 18, 2010 | 02:17 AM
kadettcqp's Avatar
Default Hall sensor
I have heard that some LS-based engines have hall sensors with 5v output and others have 12v output. Does anyone know which engines came with 5v and in which years.
I am hoping that my 98 LS1 has an 5v hall sensor but can anyone confirm or reject that? I know that it should be possible to measure the voltage, but my engine is nowhere near assembled so i hope that someone has the needed knowledge to answer my question here.
Old Mar 18, 2010 | 06:18 AM
eseibel67's Avatar
Checked the wiring diagram on an 01, and the cam and crank sensors use a 12v volt ref. I would assume 98 is the same. Hopefully someone can confirm.
Old Mar 24, 2010 | 12:46 AM
1SLwLS1's Avatar
I cannot confirm nor deny this, but thought I would throw this curve ball in the mix.
BWD's website has a camshaft position sensor for a 98 and cross reference only 98 model camaros and firebirds, which is CSS126, while the 99-02 camaros and firebrids use CSS1531
If the difference is the output voltage, seems like you would get your 5V response compared to the 2001's 12V
