Extended duration..why?
PV clearance becomes more critical not with lift and duration, but with lsa getting closer (and overlap getting bigger).
Scenario 1.
What would happen if I were to raise compression using the gaskets and milling the head but continued to use the Stock cam? I would imagine this would cause too much DCR and would lead to detonation issues correct?
Scenario 2.
Raise compression using the same methods above but used an extended duration intake cam and stock exhaust cam
Scenario 3.
Opposite of 2. Use a stock intake but extended duration exhaust
Thanks
Scenario 1.
Scenario 2.
Scenario 3.
Thanks
IOW, don't get lost in the details and lose sight of what you are trying to accomplish. Don't use late IVC to reduce cylinder pressure; rather use it for better cylinder filling.
I'm not sure that your analysis of the cam change in the "kit" is for the reasons you cited. You might ask those who developed the kit. Not necessarily someone who just markets it, but the person who did the development work on it. You might be surprised.
My $.02
Jon
My $.02
Jon
