Advanced Engineering Tech For the more hardcore LS1TECH residents
blueprinting help
Old Jul 16, 2010 | 08:55 AM
bp944's Avatar
Default blueprinting help
I know this is not quite the place to post this but the other sections haven't answered my posts. So I was hoping I could get a little info here, thanks.
I'm running a dyno program and I need to find:
Piston Down from TDC,
Volume above piston,
Intake valve diameter,
exhaust valve diameter.
Induction Flow
I'm blueprinting an engine that I plan to build so I don't have most the parts on hand so measuring them is not an option.
I'm building is a ls1 block honed to 3.903, patriot stage II 59cc heads (.650 dual springs), 102mm FAST intake set-up, +2cc forged pistons, stock crank. What would those numbers be?
It would be even better if I know in general where to find these numbers becuase I plan on trying difference combinations.
Old Jul 16, 2010 | 10:26 PM
bp944's Avatar
I really need help with this, please.
