Advanced Engineering Tech For the more hardcore LS1TECH residents
Crankshaft end play?
Old Aug 31, 2010 | 08:56 AM
Oldsmobility85's Avatar
Default Crankshaft end play?
I have a 406ci sbc I am assembling and I am wondering what kind of crankshaft end play I should shoot for. Right now I have .0035 or 3.5 thousandths. It is a factory 400 block with clevite H bearings and a eagle 4340 forged crankshaft.
Old Oct 8, 2010 | 09:55 PM
melsie68's Avatar
That is on the tight side. I usually shoot for .007-8". You will need to take out the thrust bearing (rear main bearing) and take material off of it until you reach the desired clearance.
Old Oct 9, 2010 | 10:27 AM
ChucksZ06's Avatar
I think you are fine at that. It will loosen up some after you use it and will be just right.
