Advanced Engineering Tech For the more hardcore LS1TECH residents
Negative effects of negative offset wheels?
Old Dec 7, 2010 | 05:20 PM
01Blk*SS*'s Avatar
Default Negative effects of negative offset wheels?
Like the title says, I was wondering what the effects of negative offset wheels contribute to the mechanical design of an axle,rear end, handling, etc. ie. ~4.75" backspacing.
Thanks.
Old Dec 10, 2010 | 06:31 PM
01Blk*SS*'s Avatar
any one?
Old Dec 13, 2010 | 09:35 PM
joecar's Avatar
Negative offset places the centerline of the wheel further outward from the hub/bearing...
this places moment/torque loading on the bearing;
it also changes the scrub radius on the front.
Old Dec 14, 2010 | 12:51 PM
01Blk*SS*'s Avatar
Do you mean inward?
Also can you explain scrub radius a bit more?
Thanks!
Old Dec 14, 2010 | 12:52 PM
01Blk*SS*'s Avatar
Nm outward makes sense!
Old Dec 14, 2010 | 01:01 PM
01Blk*SS*'s Avatar
Would moving the wheel centerline inward or outward equal amount have an the same magnitude of moment? Say +50mm compared to -50mm offset.
The reason I ask is that I had my rear end narrowed 3" per side to run deep dish wheels. Stock the offset is 50mm and after narrowing, I will be running around a -30mm offset. This would equate to a lower moment and reduce loading on the wheel bearing correct?
