Momentary engine cut module for WOT shifts
We are developing a momentary torque cut module for the GM LS engines using the factory electronics so that you can use face-plated and other similar transmissions and perform a full throttle clutchless shift.
Here is a link to the thread in the transmission section:
https://ls1tech.com/forums/manual-tr...l#post14660233
We are aware this is going to be a low volume product. The primary reasons we are able to justify producing the torque cut module are:
- we wanted one for ourselves anyway (we are using the OEM ECM on our 1240 rwhp 2010 LS9 Camaro) so we were going to do the development work anyway
- our existing 2-step product could be adapted to perform this function so some of the tooling/packaging can be shared with that product to help keep the cost down in low volumes
In addition the GM ECM's and software are able to control a wide variety of engines and software like EFILive and HPTuners make them fairly easy to calibrate and much less cost than a Motec, Bosch Motorsports, or other aftermarket ECU.
