Advanced Engineering Tech For the more hardcore LS1TECH residents
sensors???
Old May 14, 2011 | 08:08 PM
2000dreambird's Avatar
Default sensors???
ok so i wanna put all new sensors in my LS3 when it shows up, there is no point in taking the old ones out of my LS1.
my question is do i buy the sensors for a 00 trans am LS1, or do i need a different kind? im not sure if they will fit the LS3 or not, and i know the LS3 had a 58x reluctor in it, well mine will have the 24x so i know that plays a part in which sensor i need ..... i was told to just get the LS! sensors i just want to get a second opinion !!!
Old May 15, 2011 | 02:37 PM
Pocket's Avatar
Put the proper sensors on your LS3 for a GEN IV engine. If this is going in your 4th gen, you'll need conversion boxes to adapter the incompatible sensors to run on your old PCM/harness
Old May 15, 2011 | 04:18 PM
but the problem with that is my LS3 will have a 24x reluctor and not a 58x which is what the LS3 sensors should run off of
Old May 15, 2011 | 07:57 PM
Pocket's Avatar
If you're running a 24x crank, then use a 24x sensor. Dont forget to swap the cam sprocket for a 1x from a LS2. LS2 cam sensor
Use the conversion kit for the knocks, drill/tap the block
Intake and TB sensors make no difference which is which
Old May 15, 2011 | 09:43 PM
its coming from Texas speed with the appropriate cam sprocket, and the LS2 conversion
