Advanced Engineering Tech For the more hardcore LS1TECH residents
Speed Density
Old Nov 29, 2011 | 08:30 AM
CaMaRo67RS355's Avatar
Question Speed Density
Those of you that are on speed density are you guys just using a hose to delete the MAF or are you guys using aluminum pipe to keep the hose from collapsing?
Old Nov 29, 2011 | 01:57 PM
blackls1ta00's Avatar
Default sd
its not a good idea if you want mileage and streetability,im changing mine back to maf.it wouldnt be a benefit unless your supercharged.heres a pic of mine.its ceramic and i got it from jegs.
Old Nov 29, 2011 | 09:48 PM
fergymoto's Avatar
If a hose were to collapse that would be an indication that you have a major intake restriction. A silicon coupler would be fine if you can find one in the right dimensions.
