Advanced Engineering Tech For the more hardcore LS1TECH residents
pic: purpose of this plenum on intake duct ?
Old Jun 6, 2012 | 11:36 PM
1 FMF's Avatar
Default pic: purpose of this plenum on intake duct ?
what is the purpose of this plenum or whatever it is called hanging off the bottom ? This is the duct that runs from the air filter box to the throttle body on an 8.1L in a 2006 Sierra. I mistakenly got a duct for the 6.0L gas engine which is slightly different shape but that also has a plenum thingy hanging off it.
I am going back to oem configuration on the truck. It came with a K&N cold air kit- cone filter replaced the air box and the K&N duct was just a straight pipe that went from air box & MAF sensor to the throttle body.
So my question is how come the OEM setups have this plenum thingy, what is it's purpose? And why does the K&N setup not have it?
here is a pic of the k&n setup
Old Jun 7, 2012 | 01:27 AM
Wnts2Go10O's Avatar
wrong forum but its a silencer
Old Jun 7, 2012 | 09:08 AM
1 FMF's Avatar
what forum should it be posted in ?
how does it work? what kind of noise does it silence ?
Old Jun 7, 2012 | 04:24 PM
Bo185's Avatar
It cuts down on intake air noise. For noise emission abatement. Basically so the truck isn't too loud inside.
Old Jun 7, 2012 | 06:09 PM
Valkyn's Avatar
Looks like basically the same thing as the 'donkey dong' silencer on the LT1 intake elbow.
Old Jun 9, 2012 | 11:02 AM
Old SStroker's Avatar
It can be used to "silence" or to just cancel out frequencies that are annoying, or to give a cool power sound at WOT (wide open throttle) in the higher rpm ranges.
My gues is all of the above for the one pictured.
FWIW, the principle is the same one CORSA uses on their mufflers to tune the sound.
Jon
Old Jul 30, 2012 | 03:51 PM
409CISecondGen's Avatar
Corsa use 1/4 wave, that looks like a Helmholtz. Helmholtz have a much lower Q and wider bandwidth than 1/4 wave resonators.
