Electronic trouble shooting
Has anybody attempted to use an adjustable resistor in their late modle f body wiring harness to address a lying oil pressure guage in their instrument panel, i have done this on older stuff but not sure how it would do going through a module ???i have an adapter to put in place of the oil filter to read the oil pressure . Open to any thoughts
FWIW - the only way the current would come into play would be whether the oil pressure gauge is digital and requires a bias current in order to also drive the LCD screen. If the oil pressure gauge is analog then you should be fine to use the potentiometer without any problems.
