Advanced Engineering Tech For the more hardcore LS1TECH residents
5.3 Crank
Old Jul 6, 2013 | 06:01 PM
buffalohd's Avatar
Default 5.3 Crank
Well I am new to the world of the LS. I am building a street rod. decided to go with a 5.3 truck engine. The only reason for going with this is the cost and have good things about building them. I purchased a 2003 out of a med duty truck. I would like to get the most out of my build. First I have heard that a LS6 cam wakes it right up? I have good and bad things about using the stock heads? The main thing is I would like to run a GM performance ECM and harness that will work well with a 4l65e. In order to run the new ECM I need to put a 58x crank. Will a late model crank bolt into a early block ( same size journals)? Any help would be appreciated.
Old Jul 7, 2013 | 06:54 PM
Old Geezer's Avatar
Wrong forum.............
Old Jul 7, 2013 | 07:46 PM
buffalohd's Avatar
Sorry where should I be posting this?
Old Jul 8, 2013 | 09:22 AM
Guitar's Avatar
One of the internal engine forums: https://ls1tech.com/forums/generatio...rnal-engine-5/ A moderator may move it if you ask them.
Are you boosting it or leaving it N/A? If you plan to leave it N/A, get a nice either off the shelf or specced cam rather than going with an LS6 - it will be more expensive, but more power and what you want in a cam. The heads are 243 heads probably, and those are good heads to use - you can even have them sent off and P&P for some extra gains if you like. There is a wide range of possibilities available, just need to know your plans for it.
Old Jul 9, 2013 | 06:53 AM
buffalohd's Avatar
Thanks for the info.
