Advanced Engineering Tech For the more hardcore LS1TECH residents
LS stock crank offset grinding
Old Mar 10, 2014 | 11:55 AM
LilSlo1's Avatar
Default LS stock crank offset grinding
Does anybody know how far you can offset grind the rod bearing journals on a stock LS crankshaft ?
Plan is to cut the rod journals down to the honda journal size (2.100 to 1.889) and off set grind to slightly destroke so the engine fits in the cubic inch rules requirement for the class.
Old Mar 11, 2014 | 12:59 AM
Blown06's Avatar
8 Second Truck Club
Good question. I haven't heard anybody use the term "offset ground crank" in a long time. Probably not common enough to get answered here. Might call some crank grinders.
Old Mar 11, 2014 | 11:38 AM
LilSlo1's Avatar
That's what figured, I was just hoping somebody might have done some grinding.
Old Mar 16, 2014 | 05:56 PM
stevieturbo's Avatar
Are there no off the shelf cranks available in the stroke you need ?
Old Mar 16, 2014 | 11:41 PM
A.R. Shale Targa's Avatar
I'm about to have a stock crank offset ground to correct the piston deck height but over .200 offset is not a good idea since not only will it weaken the crank but the oiling holes will move to an undesirable location on the bearings and could cause durability issues. IIWY I'd consider .100 max.
Some real good crank shops can also nitride for you as well.
