Engine Harness Tucking, Sensor reliabiity issues, electrical resistance issues.
make your splices like the GM splice packs. totally water proof.
the old rule of thumb of how much amperage a certain gauge wire can handle per length has been overally conservative for years, you can put a lot of current on 18 and 20 gauge wires. the resistance in ohms for a thin 20 gauge wire is about 10 ohms but for 1000 feet of wire, so only about 0.1 ohm per 10 feet. with 10 amps on that 10 foot wire you would have about a 1 volt drop which is not a problem in a 12vdc system for most loads. regarding computer equipment, those aren't high amperage loads, they are not even over 1 amp most of the time so if you do the V=IR math it's no where close to being a problem. i would only be concerned about using a wire in the harness which is thin for some other purpose than it was intended- if you used it to power the relay for your fuel pump or headlight then you would have a problem.
http://en.wikipedia.org/wiki/American_wire_gauge
