Advanced Engineering Tech For the more hardcore LS1TECH residents
cam timing?
Old Jul 6, 2015 | 07:41 PM
OkieDave's Avatar
Default cam timing?
Why do some cams have 4 degrees advance ground in? When they do, should I set it 4 retarded to make up for it?
Old Jul 12, 2015 | 08:11 PM
Kip Fabre's Avatar
[QUOTE=OkieDave;18873965]Why do some cams have 4 degrees advance ground in? When they do, should I set it 4 retarded to make up for it?[/QUOTE
The reason some cams have 4 degrees or 2 degrees advance ground into it is because the guy or company that speced the cam wanted valve timing events that way so don't retard it back to 0.
Old Jul 22, 2015 | 09:42 AM
radar502's Avatar
I have the same 4+ called Comp. it's ground into the cam dot to dot install. It is what it is ..
Old Jan 2, 2016 | 01:38 PM
panic's Avatar
Leave it alone - at least until you try it out.
