Adding load by adding weight while reducing timing at the same pressure ratio
For this example I will use a naturally aspirated engine (although my event was on a turbo car) for clarity and simplicity,
ex.
I have 6L engine with a map sensor,
I go to wide open throttle while driving and notice my map sensor shows 0psi like it should.
I tune the ignition timing by EGT (lowest egt with minimum timing advance) and by torque output (best torque +/- 5% with minimal timing advance).
Now, I add 2000lbs of weight to the vehicle in the trunk, and do this again.
Suddenly my octane is insufficient, and the timing is too advanced. I expected this of course, but I do not have a name for it. Clearly "Map" tuning is not "load" tuning, since I just increased load significantly (the force opposing the connecting rod is higher) and the LOAD scale still just shows the same old 0PSI.
The reverse is also true, I REMOVED 2000lbs from the vehicle and suddenly the engine could stand quite a bit more timing advance at the same octane. Same 0PSI shows on my map sensor.
Anyone could tell me what this is called, I would be most appreciative... thanks
I went on to explain you could peg the map sensor to 0psi in neutral if you wanted, free-revving the engine, and that each gear afterwards, 1, 2, 3, etc... applied a different form of load to the connecting rod as the engine accelerated more slowly through each gear per unit time. Ultimately what I am getting at is that the force required to turn a dyno roller, for instance a dynojet roller, which is a given weight, could not actually simulate the rolling resistance of the vehicle, and this would alter final timing values, the greater the descrepancy between vehicle rolling resistance and dyno roller turning resistance would result in a "perfect dyno tune" being farther and farther off it's mark once the vehicle hit the road, with the timing of course being too far advanced if a heavy vehicle were dyno'd on a lightweight roller.
So theres no name for it? I suppose we could call it "load based tuning" but that leaves something to be desired. How about "multiple rolling resistance load based tuning" or "actual rolling resistance fine tuning".
I've come to expect this sort of thing, and for the last five or eight years now I have been tuning my cars on the street first, and then taking it to the dyno for 1-10 passes just to make sure everything was peachy. And the cream was, if I knew the vehicle was heavy, like a MKIV supra for example, I also knew it would pick up a significant bit of power with a bit more timing on the dyno, even though the street timing unit I had picked out for it was optimal for the real road.
ex.
