LS Valvetrain Limits Before it gets too unreliable?
Thank you
Its the same with RPM vs. stroke length: the inertial load on the rod and journal vary (roughly) as the square of the RPM, so the obvious 3.000" vs. LS1 etc. 92mm isn't 3.622 / 3.000 = +27%, it's closer to +12% RPM at the same tensile load. 7,000 RPM > 7,848 RPM.
The math? Where
Z: piston acceleration, in f/s/s
N: RPM
S: stroke length, in inches
n: rod ratio
2189: a constant
Z = (N^2*S*(1+1/2n))/2189
The math? Where
N: RPM
n: rod ratio
2189: a constant
So Far if I'm revving to 8500 I'm thinking
3/8 pushrods
Titanium Valves coated
Shaft mounted rockers
Correct springs
What would be the first thing I'd be looking at breaking at that RPM?
