CO-2 Chamber Spark Testing for Coil Output Hi All, I too agree with Scientific Method. That reason caused my design of an eight channel, eight Spark Plug, CO-2 Pressure test chamber with Sight Glass observation of ignition quality and sell this to all who would ask. The common coil output test of a Pico Load (SAE Method) is a fixed load. My "chamber" can test Spark Plugs, SPW, Coils easily. The ability to connect to a Scope is also easy. I can change the Chamber Pressure, the boost, on the "fly". My ability to test ANY coil, SPW, SP, etc. exists. WHAT WAS FOUND : The BRISK Spark Plug was tested in my chamber with cutting of the ceramic allowing a "drop" of the center electrode into the chamber bottom, good luck it was NOT into a cylinder ! Who would be interested/join me in this project ? Lance |
It sounds great but don't you need like 2000psi to simulate combustion setting? |
Originally Posted by kingtal0n
(Post 19842231)
Cylinder Pressure = DCR Hi King/Gary, thanks for the kind words/interest. THESE are the questions we need to help LS-1 Tech Members. MY chamber will go to 800PSI of CO2, on a Hot Day. Now understand the start of combustion, the cranking cylinder pressure of 200-400 as common. This is the pressure point that the Spark Plug MUST ionize the gas. ONCE the Arc has been established, the Voltage Requirement for Current Flow DROPS a great amount. I AM SURE many here have witnessed the "firing line" on a Snap-ON engine scope. ANOTHER GREAT measurement is ARC Duration vs Spark Plug Gap in Micro Seconds. THUS I ask ALL here WHY is this time measurement important ? Lance |
I would say the spark duration, or dwell time, is proportionate to "firing efficiency". The longer the spark, the better the fuel/air mix gets lit off. Gary |
The Spark Plug Burn Time duration is used to determine the condition of secondary ignition components ( anything after the secondary windings of the ignition coil- spark plugs, wires, central HT lead, coil tower.) If the duration of one cylinder is much shorter or longer than the others, a problem with that cylinder is indicated. The length of the spark burn time is directly affected by the amount of secondary coil voltage available, the amount of voltage required to overcome secondary circuit resistance and create the spark, and the amount of voltage remaining to sustain the spark ( in relation to the conditions within the combustion chamber of course) |
ARC Duration Hi Gary, your term "spark duration" is a rating of the IGN-1A coil specification with definition as the term of Arc Duration as the SAE common word/term standard with a report of 3.2mS at a Coil Dwell of 3mS/14 volts. Now your longer/better analogy is understood/fair WHEN older style ignition types, MSD CDI styles, are compared. When a coils ARC Duration is MUCH GREATER, modern coils, the Arc Duration CAN be TOO LONG. (energy wasted) The Scott tech is also correct, a very good way to describe HOW those items effect Arc Duration AND how EASY it is to make changes in the spark firing line. What Scott stated was the a SPW wire of 50 OHMs per foot compared to a SPW of 250 OHMs per foot WILL effect Current Flow into the cylinder, which I too AGREE. This IS WHY a higher resistance SPW of LS style (1/2 foot in length) at 250 Ohms WILL increase the ARC Duration over a LOW OHM wire. Scott stated that the Spark Plug effects the Arc Duration, true, with that specification of Spark Plug Gap. One goal of mine is to test each LS coil, CO2 Chamber testing, by Scope measurement/pressure measurement observation AND report best SPG/Wire resistance for a specific RPM/Boost Pressure/NOS shot. Am I on the correct path ? Lance |
I have a feeling you are. My knowledge of ignition theory, as you have seen, is a bit obsolete. Keep this going! I am learning, slowly but surely.... |
the only thing I know about ignitions is from a book written by Dr Jacobs, who used to run jacobs electronics and they sold various ignition products witch I owned many of....sadly he sold his company off and his products are not the same as they once were but the book might be relevant today....if you can find a copy.....but very informative none the less |
Dr. Jacobs was/is pretty sharp, which can't be said of the morons running the company now. One thing they know well is the hard sell.. |
Energy = Amps 302mj/12 AMPS@10K NOT Hi Gary, I too agree with YOU AND their OWN Data REPORTED of a CDI output of 302mj at the RPM of 10K with a input of 12 AMPS ? The MATH is NOT Correct, the AMP rerquirement should be greater than 35 RMS. The first Jacobs product was a DC/DC converted that raised coil voltage from 12-16 volts, a GOOD thing in that day. (WWII) My NEW TFD coil/ignition system runs at 46-48 Volts powered by my Red Rover batteries 12@3.74 Volts. Lance |
I do remember Jacobs selling a voltage step up device....primary aimed for audio....increased voltage and filter for cleaner signal....never had one but wanted it ! speaking of which ....I have seen voltage steppers ( 12 v to 14 or 16v ? ) designed to increase voltage to the coils ( or just ignition circuit in general ? ) for the LS1s....any thoughts on this device ? |
Coil Supply Vss Hi Sj, electrically your are correct about the fact that a higher supply voltage WILL Increase coil Flux Speed. Thus Coil Dwell times would be lower. There ARE LS coils with internal IGBT Current Sense circuits, NOT GOOD for a Voltage Increase. The Modern PCM measures changes a Battery Voltage with the same changes in Dwell Time to stabilize coil output. Sorry SJ, a good thought though this method worked well when ONE coil was used with a Distributed Ignition System, NOT my DIS. (COP/CNP) Lance |
© 2024 MH Sub I, LLC dba Internet Brands
