Advanced Engineering Tech For the more hardcore LS1TECH residents
5.3 PTV Clearance
Old Sep 6, 2018 | 12:04 PM
Michael Sparks's Avatar
Default 5.3 PTV Clearance
I was wondering if anyone out there could help me with some PTV clearance guess work. I'm building a 5.3 with 4.8 flat tops, using the 862 casting head shaved down .035 with the larger 2.00 inch valve installed. The cam I want to use has .610/.617 lift, 223/231 duration at .050 and a line seperation of 112 degrees. Am I going to hit? If so how deep of reliefs do I need in the Pistons?
Old Sep 6, 2018 | 12:15 PM
This should be in Gen III Internal, not here.
Old Sep 6, 2018 | 12:31 PM
Thanks, I'll post it there
Old Sep 6, 2018 | 12:37 PM
Then hit the Edit button at the bottom of your first post and delete that post, which will delete this thread.
Old Oct 31, 2018 | 04:03 PM
Old Geezer's Avatar
Lightbulb
^^ Good idea!
Before you do, READ the sticky at the top of the forum....This entire forum is eaten up w/ "101" ??'s.
