Advanced Engineering Tech For the more hardcore LS1TECH residents
piston / deck height change with temp
Old Apr 6, 2019 | 01:06 AM
patSS/00's Avatar
Default piston / deck height change with temp
I don't know if this is advanced tech, anyway... As the engine heats up, does the piston out-of-the-hole height over the deck increase or decrease? I think with an aluminum block it would decrease, since AL has a larger expansion coefficient than iron / steel. So, the block deck height would expand more than the rods/crank/pistons. Is that right? Not really something you could measure very easily.
Old Apr 6, 2019 | 12:57 PM
I think you are correct, with the coefficients of expansion what they are.
Old Apr 6, 2019 | 01:04 PM
patSS/00's Avatar
Well if this means the quench area would increase, that would possibly allow more detonation at temp goes up. Of course that happens anyway, but maybe this is a factor, with aluminum block engines.
