2 Injectors, 1 Driver: E38 running 16 injectors bathched
My understanding is that the e38 can run them fine, with no impacts to timing events or such... but that the increased amps will cause the injector drivers themselves to burn up. Wiring in parallel will cause an increase from 1 to 2 amps per driver, while wiring in series will cause the injectors to get half voltage, which will impact both timing and flow, and MAY be able to compensate with tuning, but this is unproven.
Looking for some specs or engineering data on the drivers used in the e38....or some educated guesses that it will be able to handle the extra amps.
Thanks!
~Ryan
Charleston, SC
But if you did just run 2 inj of each driver, you would still be full sequential which is good..
Or just run big single injectors and a driver box ?
