Advanced Engineering Tech For the more hardcore LS1TECH residents
4l60 e with diffrent bellhousings
Old Jan 12, 2021 | 01:57 PM
lockjaw10175's Avatar
Unhappy 4l60 e with diffrent bellhousings
i got a 4.3L with a 4l60E of m30 and i brought another 4l60e with a full bellhousing i no longer need to bolt the torque converter shield
can i plug an play or is there modifcations that i need to do?
Old Jan 12, 2021 | 04:05 PM
MaroonMonsterLS1's Avatar
This belongs in the transmission section.
@mrvedit may be able to move it. Or one of the moderators of this section.
Also...if you typed a thread that made sense rather than gibberish, that will help you get better answers
Old Jan 12, 2021 | 04:45 PM
mrvedit's Avatar
Moderator
Sorry I'm not a moderator in this section and therefore cannot move it to Transmissions.
Old Jan 17, 2021 | 08:16 PM
WE TODD DID's Avatar
Swap bell housings. Everything else should be the same.
Old Jan 18, 2021 | 07:58 AM
Yea everything will be the same. Except the input shaft, stator tube, and converter
But...it'll be fiiiinnnneeeee
Old Jan 19, 2021 | 08:05 AM
Let me be a little more clear here since all you're doing is trolling.
To the OP,
There are two input shafts and stator tubes for a 4.3 and V8. 298mm and 300mm. You could have either depending on the years of the transmissions. They are easy to differentiate.
The transmission behind the 4.2L engines will not interchange with the V6 or V8 without replacing parts.
Old Jan 19, 2021 | 08:47 AM
That's a stark difference from "swap bellhousings and everything else will be the same"
