Unit Conversion calculator
6600 rpm clutch dump of death Administrator
Do you ever find that when you are putting something together (like an engine) that the assembly innevitably has some unit that you have no way of measuring. Like "torque bolt to 90 newton-meters..."
Or, someone from Australia tells me they dyno'd 440kw, well what does that mean in HP?
Anyhow, I have a small program that I have used for years. Its small, and you can run it in just about any windows environment. Better yet, its free.
http://www.joshmadison.com/software/...t/download.asp
I highly recommend you add this to your toolkit. Like I said, its free.
www.google.com will calculate and translate just about anything (well except for that kW to SAE hp example
just do "40 meters in inches" and it gives the answer. pretty cool. You can also use it as a calculator using similar logic as MS Excel.
Originally Posted by mr2guru
I've always used www.onlineconversion.com It has just about every unit of measure imaginable.
Agreed, im an engineer and use it all the time at work!
