Ignition Timing Vs. Compression Ratio
A. 11.0:1 Compression ratio, and higher timing values
B. 12.5:1 Compression ratio, and less timing
Both should run fine on pump gas when tuned correctly, but which is the better method of making the power, and WHY?
Tony
You might have already seen this link about compression but here it is again if you havent.
Compression
[ February 04, 2002: Message edited by: Bad Habit Bird ]</p>
I wont get into why I think this is the way to go other than to say the LS1 doesnt really need alot of timing to begin with since it has such a great combustion chamber.
JS
<strong>Lets say you are designing a new LS1 motor combo (I am!). What route would you choose between these two, keep in mind that I will be running 93 octane pump gas 90% of the time:
Tony</strong><hr></blockquote>I would say the 2nd one because with higher compression you would make more power and have better throttle response and the car would really respon to higher octane fuel better than the first one.Thats just me though I like high compression and I think you should get as much as you can on NA or NA/NOS.But thats just me some people say its crazy to have high compression and juice.
I would go with the compression and a HUGE for MTI solid roller setup. <img src="gr_stretch.gif" border="0"> Anybody know the compression & timing of a top fuel dragster?
<strong> Anybody know the compression & timing of a top fuel dragster?</strong><hr></blockquote>
somewhere around 6 to 1 give or take, they have lots of different pistons to use for tuning. But they also run lots of boost, can get upwards of 40 PSI. dont know what timing is for them though... Did you know that Nitromethane has a negative octane rating
I'm going to be in the minority here, but an engine will make its maximum potential power with the best ignition timing curve. Let's say you can safely run 30-32 degrees of timing on an 11-1 motor (which is pretty close to ideal with the cam & heads you're talking about running). If you had to drop the timing down to 24-26 degrees on a 12.5-1 motor to keep it from rattling, it may not make as much power as the 11-1 motor with full timing. I've seen this phenomemon for years in non-LS1 applications...can't see why it wouldn't apply here too.
Remember, you're talking pump gas here. I think you'll make more power with the 11-1 motor and max timing personally. I'd even bet money on it.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I side with PatrickG.
Top fuel runs 50' lead and maybe more.
Nitro burns so slow that's why you see it still flaming out the pipes.
You want to do something different Tony?
Ok, have MTI put in aluminum rods, go with a 7-1 piston, fill the block, put in the biggest damm exhaust valve you can ,Bearing clearance at .0035" and open up your ring gaps to .040" , maybe start out with 40' degrees timing, buy the largest injectors you can find and let's see a "fuel" ls1!
<img src="gr_eek2.gif" border="0">
Steve
J.
They must be doing something right <img src="gr_grin.gif" border="0">
edit - I've got a feeling Tony's new setup will see a lot more street miles than the SAM SS or Stephen's car though. Even though he's got a truck now, he will still probably drive it a lot on the street.
J.
[ February 05, 2002: Message edited by: Crazyquik ]</p>
If you are going with a 422+ motor with a Big *** hyd cam I would run the 12.5:1 comp with a LARGE duration cam on 110LSA. That will help bleed off compression at higher rpms due to the increase overlap. However it wouldnt be very streetable. I would hold off until you see the results of JPR's EWP on a high compression motor. If you can get away with 28 degrees timing on a 12.5:1 motor with his EWP on 94 octane I would definitely look at that route.
You haven't provided enough details.
I am going to ruin 11.1-11.3:1 comp in my new combo and a 226/234 112LSA cam. That should work well on 94 octane and 28 degrees advance.
Cheers
Chris
J.
12.2 is really too high for pump gas but it does allow you to take advantage of racing fuel at the track. <img src="gr_images/icons/cool.gif" border="0">
After saying all of that, I've seen street cars run 12.5:1 in the past but I think I would rather err on the side of safety. You know it is a hot SOB down here what with Global Warming and everything. <img src="gr_grin.gif" border="0">
Les
not very much timing for street use
a lot of timing and race gas for the track
that is the way to do it my friend <img src="gr_grin.gif" border="0">
First off more timing isn't always better, etc. There is going to be a certain timing value that is optimum at a given rpm point based on piston velocity and flame speed. Flame speed will be changed by things like chamber configuration, fuel qualities, compression ratio, charge quality, dyanmic compression, etc.
Once you can achieve the optimum advance for your setup more will only slow you down/kill engine components. But many times in the real world we can't achieve that number. It generally *doesn't* work well to have to retard the crap out of your timing to crutch ignition related problems (detonation/pre-ignition).
Will 12.5:1 work with pump gas on a stock motor? No way.
What if we throw in a huge cam and end up bleeding away a good bit of that compression - well, now we are getting somewhere.
So how can Colonel run 12.2:1? He has to run 12.2:1 with his setup to make power. That LS6 intake is still pretty restrictive, believe it or not. That doesn't mean you can't make power, but you have to work around that intake. It's cutting down his VE so much that he isn't getting a full intake charge. so his 422" of displacement aren't sucking in as much air as they can. This acts to reduce the actual dynamic compression because we aren't compressing a full intake stroke of air, but rather only what can be pulled in through the intake.
This is how nascars work - the run ungodly amounts of compression, but because they are pulling it in through that little tiny restrictor plate their dynamic compression is nothing like the calculated static.
All in all it depends on the setup, but I would rather err half a point on the conservative side and be down a few hp than half a point the other way and have to run race gas.
Chris
