Advanced Engineering Tech For the more hardcore LS1TECH residents
Displacement formuals
Old Nov 22, 2005 | 07:48 AM
DanO's Avatar
Originally Posted by moldmaker
If you are after a barometer of engine efficiency then study up on BMEP (brake mean effective pressure).
Originally Posted by Old SStroker
HP wins a lot of races. Evidently I misinterpreted you, Dan.
Not knowing if that was extreme sarcasm or not...
BSFC = Fuel to HP (efficiency, like i stated)
BMEP = Displacement to Work output (independent of fuel input..i.e. cannot gauge effieciency)
When efficiency was mentioned, i said BSFC should be used. Am i wrong?
When comparing and engines power output capability per displacement you should use BMEP.(i.e. great for comparing engines...)
