Effects of piston speed.
It's the best one I've come across. I first read it when it was the first edition before the start of the muscle car and pony car era.
http://www.amazon.com/gp/product/083...lance&n=283155
The 311 will probably produce a flatter torque curve with more linear throttle response which will be easier to control out of the turns IMHO.
Low revving high torque engines may not be aurally exciting as high RPM screaming engines, but they certainly still are effective and longer lasting engines in general.
For example if you only lost 3 indicated hp from a shorter stroke same bore (smaller) engine, but decreased friction hp by 5, you'd be 2 up at the flywheel (brake hp). Something like that. It sure would escalate the plate development costs trying to find the best combination of displacement and friction. My take was that the min. displacement rule was to minimize plate development costs.
Live and learn. I've lived a long time, and am still learnilng.
What people that were going faster were doing was cheating in millions of ways if you know all that went on in the beginning of the plate motors and then many said that they were just running small engines and that's why they were faster! NASCAR and the engineers knew better and caught many running all kinds of air leaks both illegal and some in very gray areas and also simply forbid the smaller engines to eliminate this excuse for higher rpms with the same plate. I know one NASCAR engine builder from TAMU that was on one of those teams that flew with the plates and they were cheating and saying this themselves. They never were able to lap faster with the smaller motors legally anyway so no one cared when they put a lower limit on displacement. Most people have quite a good laugh when it comes up that I talk to.
These cars are already limited somewhat by the 4150 and cast manifolds they run so as with ALL engine they are already a restrictor plate type deal at some point but maybe only 2 inches HG instead of 15!
The cars with non-SEO restrictors just get slower when you destroke them like any other engine. You have to run MORE weight with larger engines in the rest of restrictor plate racing and that's with the same or smaller restrictors than the smaller engines get to run or the big stuff will totally dominate and run away and it still does half the time so even there displacement is an advantage for sure. I could send you a movie about restrictor engines from a 24 hour builder and you would be surprised what all the big engine people and engineers say I bet.
In unrestricted form the 434 with be TONS more fun with tons more torque and power everywhere. The 310 will not keep up. I guess it would be a good rain engine or for someone that sucked or couldn't drive maybe or if you have to run on crap tires?
With engines that have enough air, the torque curve is flatter and the power curve climbs.
Yes, the 434 would have more power. And yes, it would have a lot more peak torque. However torque at the flywheel is pretty meaningless. It is torque at the wheels that counts, and that is HP.
With a 350cfm carb, I imagine your 434 would be out of breath before 6k. Depending on cam and valvetrain rules, the 311 would probably power peak in the high 6k range, with a relatively flat torque curve to there.
In a race, the 434 would eat the 311. Behind the wheel, the 434 driver would have an interesting time coming off the turns, the 311 driver would have a more linear response.
In a little approximation, using some default engine I constructed a while ago, a 434 torque peaked at 4500, power peaked at 5500, and had a 30% rev range of 4500-6500. At the shift point torque had dropped 30%.
Change to a 3" stroke 325, the torque peak was 5500 and the power peak 6500. However, torque dropped 15% from 5200-7300. A little higher, maybe 25%, in the 5500-7700 rev range.
Yes, the big motor produced 20% more peak power, and maybe even more average hp under the power curve. However, the rpm dependent torque is not fun coming out of the corners. At least not if your goal is consistent, fast times.
Unfortunately, my print screen has checked out.
Note, my 355's curve looks a lot like the 434. And getting power down coming off the turns is always on nails. With an 'N'.
Yes, the big motor is faster. The small motor is easier to drive fast. Which is why Michael Schumacher and Jeff Gordon aren't afraid I'll break their records.
It is possible to shape the torque curve a number of ways, with valve timing and intake manifold and exhaust header tuning complimenting the head flow being the major players. If your rules have carb or restrictor plate limits as well as displacement limits, the engine designer and the driver can decide together what kind of a torque curve will work best for your car/track condition and design an engine which has that kind of torque curve. It may not have the most peak hp or peak torque, but it could be quicker. Isn't that the goal?
This is a great use for good engine and vehicle simulator programs. Once you have the current or baseline engine well simulated, you can plug the engine data and car data into an acceleration program and work with the traction coefficients to simulate what actually happens. Shaping the (rear wheel) torque curve with all the available engine and gearing parameters can go a long ways toward giving you an engine/racecar you can drive. This has been done, but not often enough at the grass roots, Saturday nite bullring level.
FWIW, F1 engines have used techniques like lagging the opening of one bank of throttle plates a certain amount behind the other bank to "shape" the torque for Michael. This is in addition to or maybe in place of engine traction control.
I have little doubt that Cup engine torque curves are tailored to specific tracks. That's legal traction control. Add the illegal TC some folks claim exists in Cup and you don't have to be Jeff or Tony to be the fastest. This in no way implies these guys are using illegal TC, BTW.
Cup restrictor tracks are unique in that there is not much acceleration once they get to speed and the engine runs in a very narrow rpm band. Not so for endurance and short track racing of couse.
Try "shaping" the torque curve with a good engine design not just sacrificing one end for the other. Look at the area under the torque curve and hp curve throughout the rev range you run. You don't have to have the highest peak power on the track, but having the highest "area under the curve" is a big help. I'm suggesting some out-of-the-box thinking on engine, especially camshaft, design. There are already enough me-too engines out there running mid-pack.
FWIW, the engine should be tailored to the driver as well as the car and the track. An aggressive front-runner can use more mid-top end than someone who is maybe less aggressive and often mired back in the pack. Most engine builders advertise/sell max power numbers because that's what most people think wins. The smarter builders build engines that fit the track/car/driver. Some of them will even admit that to you. I like those guys.
My $.02
When restricted apps you usually can not give up any power what so ever and stay competitive. Remember also that many of these classes are managed competition to keep brands closer so they will all race.
The rules are also often there to help bring everyone together in overall speed so people often get confused on a true heads up setup when they look at a normally santioned racing class.A NASCAR engine is NOT fast BECAUSE it's a 358 at all. It's simply a very fast 358 BECAUSE of all the money and development. If they were allowed 400 CID with no penalties both the open AND the restricted engines would ALL be 400 CID.
Traffic changes lap to lap. And you never know who is behind you since neither mirrors nor radios (a recent development) are allowed. One lap you can be clear, the next bottled up, the next side-by-side. A big difference in corner speeds and how much power you can apply.
For practical purposes, the intake, exhaust, and carb are fixed. The only really tuning option is the cam or lash. If you are running a track with long straights and tight turns would want a different cam than a track with short straights and fast turns.
I'm not saying my engine is wrong for the track, I'm saying that an engine with a flat torque curve and linear throttle response is easier to drive than on with a hump in the middle. Not faster, just easier to drive.
P.S.
Everyone must have a scanner to get instructions from the starter, mostly line-up order on restarts.
P.S.
Can you restart in a lower gear?
The tensile strength range of these alloys:
steel alloys = 50,000 to 300,000 psi.
titanium alloys = 30,000 to 180,000 psi.
aluminum alloys = 10,000 to 100,000 psi
The upper end of these ranges is somewhat expensive for steel,
but much more expensive for Ti and Al.
For any given titanium alloy, you can always easily find a stronger steel alloy.
Titanium is lighter than steel (you can accelerate Ti components quicker for a given force, or, stated differently, Ti components create a reduced loading in response to a given motion).
But, all said, steel is still the stronger.
This is why Ti springs and other components break when used in place of steel in high stress applications.
My humble $0.02, thanks.
Joe
