Power from Forced Induction
this is from Maximum Boost: Designing, Testing, and Installing Turbocharger Systems (Engineering and Performance)
by Corky Bell
Would this not suggest that a higher SCR on a FI application is more effective given the same flow? Lowering the CR would lower cylinder pressure (less effective power).
The reason I bring this up is, with a small blower such as the MP112 Eaton (magnacharger), would you not want to max the compression in order to utilize the limited flow? lets assume that we can handle the detonation with chemical or mechanical cooling.
hopefully this is appropriate in this august forum.
The graph you have posted displays combustion pressure.
If the SCR/DCR is too high for the extra charge given by the turbo, the fuel
would self ignite from extreme pressure/heat (pre spark).
I think this is where the VE/Torque peak comes into play. Maximum compression
for the most efficient point in the VE curve.
Unless you increase the octane, or fuel type as you suggested, raising compression
too much will give you problems.
SCR/DCR is this a relationship?, are you suggesting that if I increase the DCR the engine will be less prone to detonate?
Knowing the inlet temperature and pressure we can calculate the charge temperature at TDC using the CR and manifold pressure. Would you use the SCR or the DCR to determine the temperature of the charge and then have a predictor for detonation?
Jim
If you're absolutely restricted, then you must increase efficiency, and more static compression is a good way.
You may become detonation prone in some area or areas of your operating range, like your torque peak as was mentioned. You would have to adjust your tune to cover this.
http://www.rbracing-rsr.com/comprAdvHD.htm
but this still wont relate to the efficiency of the engine and it’s propensity for detonation.
A few posts have suggested that squish volume and area can be optimize by
a thinner head gasket for the squish volume and
milling the head for more squish area and higher compression.
My guess is, to take a 243 (LS6) casting to 11:1 SCR we would need to allow .005 for the thinner gasket and .015 for milling. PVC should be OK?
Does this seam like a reasonable strategy to increase efficiency?
PVC is completely camshaft dependant.
