Advanced Engineering Tech For the more hardcore LS1TECH residents
Running surface - Lifter / Cam
Old May 4, 2006 | 10:53 AM
Cstraub's Avatar
Originally Posted by 777
Futral and some of comp's (I'm guessing they both get their cores from the same place) This has already been addressed that it was an issue with the core, not the lifters or anything else. I've had 3 different cams. The lifters were 100k miles old and had been used through the stock cam, a 218/220 cam, and a 231/237 cam. Now I put in new lifters just for peace of mind and the cam and lifters looked perfectly fine. Now I'm running the 224/224 and expect to see the same thing, no damage.
Actually the verdict is still out. One set of spauled lifters is still having analysis done and the the cam that they ran on has been requested by the bearing mfg to also be looked at during the analysis.
Old May 4, 2006 | 03:15 PM
sleepersilverado's Avatar
hummm i guess i will have to call comp. and send them my cam to see whats up. does any one else have any more info on this or were people just calling customer service?
Old May 4, 2006 | 04:06 PM
Cstraub's Avatar
Sleeper,
Did you have a cam with same type of damage? If so I would like to ask you some questions on the phone.
Old May 4, 2006 | 04:45 PM
2xLS1's Avatar
I wasn't aware any Comp cams were having this problem. I thought they were all Cam Motion and mainly FM 13s.
Old May 5, 2006 | 08:44 AM
Cstraub's Avatar
No it is accross the board. In the cases of the F13's the spauling happened very quickly.
Old May 7, 2006 | 07:11 PM
yes i did
Old Aug 17, 2006 | 02:03 PM
Tonner's Avatar
Originally Posted by Cstraub
. . .or lack of lubrication that led to the spauling and is caused by several factors being present to create the situation.
Roller lifters don't have to be changed with every cam change. The lifter needs to be inspected and if suspect to wear then new lifters should be installed.
but is there any way of inspecting the lifters without removing the Heads ?
Old Aug 17, 2006 | 04:20 PM
Lafngas's Avatar
The Heads have to be removed on the LSx work, work, work
Old Aug 19, 2006 | 12:03 AM
Tonner's Avatar
We removed my trusty old comp cams 216/220 and found it to be totally stuffed all lobes worn with one intake lobe spalled for at least 1/8" in from the edge around the toe of the lobe, talk about gravel, it was rough as.
So the heads will come off to replace the lifters
Old Aug 19, 2006 | 12:59 PM
Tonner's Avatar
Here is a pic,
Click on the pic HERE.[IMG][/IMG]
Old Aug 19, 2006 | 02:00 PM
joecar's Avatar
Here is a pic...
Tonner, g'day mate, do you have any pix of the lifter that ran on that lobe.
Old Aug 19, 2006 | 02:36 PM
  #32
Tonner's Avatar
No sorry not yet we haven't removed the heads yet,
I will post pics as soon as we do.
we got this far with the blower install before we took a good look at the old cam
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Aug 20, 2006 | 08:03 AM
  #33
Tonner's Avatar
Larger pics.
try again soon
Old Aug 28, 2006 | 01:51 AM
  #34
Tonner's Avatar
Removed the Lifters and found no aparent wear caused by the spalled lobe. must be tough little buggers.
