Advanced Engineering Tech For the more hardcore LS1TECH residents
Knife Edging Cranks?
Old Jun 4, 2006 | 12:01 AM
MSURacing's Avatar
just go with a complete dry sump kit from Katech. They use a Razor 2 stage suction pump, an ARE pan and the standard LS6 oil pump. You will need to use a 12 quart Petersen tank, but this will get you the horsepower and reliability you will want from your setup. I think the kit is around $3000 or so. Give Jason a call, he can set you up.
Old Jun 4, 2006 | 09:12 AM
NoMoreFWD's Avatar
The August issue of Circle Track magazine has an article by David Vizard on crank profile and coatings. The first test compares 3 3/4" stroke square face and aero counterweight Scat cranks in a wet sump motor. The aero counterweights were good for 3.5 hp at 5,500 rpm, up to 9.9 hp at 7,250 rpm. This motor had a peak hp of 470 at 6,250 rpm.
The next test is a teflon based coating on a dry sump motor crankshaft, with a 3 3/4" stroke.The coating was worth 8 hp at 7,500 rpm, but gains were not seen until about 5,000 rpm. This motor had a peak hp of 570 at 7,250 rpm.
Old Jun 4, 2006 | 11:18 AM
1989GTA's Avatar
Wasn't going to knife edge the crank but I'm glad I did after reading this. Decided to go with the aero style and the cost is $200. Any ways doing the math and assuming the horsepower gain is linear I came up with this.
After rounding off I came up with a 1 horsepower gain for every 275 rpm above 5500 rpm. So at 6050 rpm that would equal 5.5 horsepower. At 6325 rpm that would equal 6.5 horsepower.
Old Jun 4, 2006 | 11:27 AM
NoMoreFWD's Avatar
Your calculations are very close. In the test I refered to, the gain was 5.5 hp at 6,000 rpm and 6.4 at 6,250.
Old Jun 6, 2006 | 12:39 PM
BADSZ28's Avatar
I read about a test that gained 10hp from the knife edge and another 10hp from a coating. I think it ws a 4.0" crank in a 383. I would imagine the bigger the stroke the more power you free up from these. Then throw on a vacuum pump and see even more.
Old Jun 6, 2006 | 01:11 PM
MrDude_1's Avatar
anyone know a good source where i can read more about this "oil shedding" coating?
Old Jun 6, 2006 | 03:44 PM
aggiez28's Avatar
polydyne.com
Old Jun 6, 2006 | 09:34 PM
SStrokerAce's Avatar
FWIW the Circle Track on the newstand now has this article in it by Vizard.
Bret
