Need FAST EFI Dashboard sensor descriptions..
There's nothing on their website...in the operation manual..or in the software's Contents/Help section..
Thanks Ahead for any info!
Matt
Section 14 & 28. You can also fire up the software while connected to the ECU and see for yourself.
901-260-3278 Jay or Ron - you are sponsored by them ...right? They've always been helpful when I called. There's also a number to the Michigan office, but that's next level. You should be able to get all the info you need from the number I posted.
http://www.fuelairspark.com/Products...dashboards.htm
-for non XFI systems.
there are "no" descriptions for the non-XFI ecu Dashboard sensors..
I had a copy at one time..that was copied out of a "Fel-Pro" manual that
listed them all..but am unable to locate..
and yes..I could call..and Dave Henninger is the guy I know best..
but I figured it would be info that was readily available to about everyone on the net..and that once posted it would be a good source of search info..
so far I'm finding out that maybe I had been the only one with this info..
once I do get it..I will post it here..
