Advanced Engineering Tech For the more hardcore LS1TECH residents
Physical limit to power?
Old Aug 12, 2006 | 02:32 PM
Wnts2Go10O's Avatar
Default Physical limit to power?
ok, so i was thinking about how top fuels literally run on the edge of exploding all the time churning out ~10,000hp or so. my question is, is there actually a limit to haow much you can get out of any single engine? i ask because of the pressures in a top fuel will be enough to flash most things to a solid including the fuel inside the motor. any ideas of the actual physical limit to any given engine?
Old Aug 12, 2006 | 03:02 PM
2002_Z28_Six_Speed's Avatar
Cross-sectional area of the parts surely limits your max power.
Massive increases in the scaling of the parts then again translates to lower rev up.
Old Aug 12, 2006 | 05:11 PM
LTSpeed's Avatar
Originally Posted by 2002_Z28_Six_Speed
Cross-sectional area of the parts surely limits your max power...
That and available materials of course. I'm thinking those new amorphous metals may let us push things to a whole new level in the not to distant future though!!
Old Aug 12, 2006 | 06:03 PM
lookin4aTA's Avatar
i would think that engine size would have alot to do with it as well. wouldn't something smaller be more likely to let go at a lower power level than somethihng bigger? eg. a four cylinder thats only ~120 inches compared to a BBC thats 500+ ci?
Old Aug 12, 2006 | 11:18 PM
Wnts2Go10O's Avatar
yea it would. by laws of physics you can only get so much packed into a given space. top fuels use ~500cid motors. im not really wondering about the materials in the block and heads but more the limit to the actual amount of "stuff" you can cram into the cylinder.
Old Aug 13, 2006 | 12:31 AM
Yes! Top fuel cars have huge cylinder heads with extra extra long head bolts. You can't do that in a street car. The engine has to be compact and running no where near what it could handle for reliability.
Old Aug 13, 2006 | 08:47 AM
Old SStroker's Avatar
Perhaps Top Fuel engines are closer to 7000 hp than 10, but your point is a good one. The engine builders continue to coax more power out of them, but NHRA limits not only displacement, but now rpm and nitromethane percentage.
Much of the hp comes from the nitro which contains it's own oxygen, The huge blowers are cramming in massive amounts of air and the fuel systems inject enough fuel to "hydrolock" (or completely fill up the area above the piston at top dead center) with liquid fuel. The limit is 85% nitro now, down from 90% a few years ago and unlimited before that. Rpm is limited to about 8400.
Nitromethane has complex chemical reactions when ignited which are more than just burning like gasoline/air mixture. That accounts for much of the power. If they were allowed, they could spin the engines faster, use higher percents of nitro, pump in more air and inject even more fuel and produce more power. Materials technology can keep up with the demands if you spend enough money on them. Rules limits keep the races closer, keep the spending somewhat under control, and still provide an exciting 330 mph 4.5 second show.
Remember a T/F engine running at 8200 rpm from the green light for 4.6 seconds only turns over about 650 total revolutions in anger. That's only 325 firings of each cylinder before a rebuild. Even then losing a cylinder or 2 is common.
Old Aug 13, 2006 | 09:57 AM
bygblok's Avatar
even with more amounts of nitro literally "crammed" into the cylinder you still have a point of absolute saturation in the cylinder where the mix can no longer flow. It used to be normal to see a %95 mix of nitromethane but as you said, the rules now limit the performance through detuning and taking away gear as well. It WOULD be interesting to see just how much a TF motor COULD take at it's absolute limit and actually be able to hook it to the track and get a speed/time. Since there are no dyno's that can handle it you still would need to use the formula manually to get a rough estimate of HP figures and account for drag, tire slip and parasitic loss. I can't even fathom what is pushed of the flywheel on one of those monsters.
Old Aug 13, 2006 | 12:52 PM
Wnts2Go10O's Avatar
i say 10 because they are slipping the clutch the entire way and ~1/2 the power is getting to the track. but like byg block said, theres gotta be a point close at hand where the motor has jus reached a saturation point where theres no more you can get in it. since they switched to 85% ive heard of teams actually making more power because of it not less. maybe the motors are relying more on the nitro/methanol mix than they are on the actual a/f. its hard to imagine the massive pressures they see with nitro.
Old Aug 13, 2006 | 01:32 PM
bygblok's Avatar
the static compression ratio changes enough with the growth of the motor under heat but can you IMAGINE the running CR at full boost from the lung and add to that the pressure from the bang??!! I wonder what formula you'd have to use to figure the operating ratio that thing works under. Consider thermal expansion, total growth in internal volume due to the explosion..... holy smokes it'd have to be oh say...... 300.1 or so??
Old Aug 13, 2006 | 03:34 PM
gun5l1ng3r's Avatar
Are you saying they have a 300:1 SCR?
Some of your posts are hard to follow, but they seem to have good information.
Old Aug 13, 2006 | 03:41 PM
AlkyInMyBlood's Avatar
TF is all about controllable hp. Nitro is probably the least understood fuel used today.
Nitro is very load dependent. More load = more HP. Nitro also loves DCR, but hates in in the respect of fuel volume. The hotter the incoming charge, the better. Alot of nitro stuff is oppisite from normal thought. You almost control power level with clutch application. Every tuning choice in T/F is a catch 22, its just a game of who guesses better.
Old Aug 13, 2006 | 06:51 PM
I'd say you have a trace of nitro mixed in your blood, AlkyInMyBlood, or did you mean the sippin' kind?
Old Aug 13, 2006 | 07:28 PM
bygblok's Avatar
no, you could never crank it with a 300.1 static ratio. I'm talking about operating CR with all the squeeze the blower is throwing on it as well. Also, those motors grow quite a bit in CID in one pass as well. When it's first put together you can usually spin the motor with a very small ratchet because the tolerances are so huge and sloppy. It quite literally "grows" in to itself as the heat builds. Once it grows and runs out about 250ft the thing is pretty much a diesal at that point. The fuel/air mix explodes under pressure without much help needed from the mags. They help burn whats left of the charge after it lights on it's own. Engine theory is pretty much tossed out the window for common use on those monsters!!! Hell, everyone knows an internal combustion engine spends it's entire life trying to destroy itself....... a TF motor actually succeeds in almost every pass only to be reincarnated for another round if the main webs stay in it!!
Old Aug 13, 2006 | 07:31 PM
bygblok's Avatar
very well put about the catch 22. The alcohol motor I work on is similar but easier on parts and not quite as hairy!! I just hate tuning it because it's so damned hard to get a plug read. Had a fuel pump going away in it a month ago and had a hard time finding it. It was fine for a half-track pass but when high gear pulled it would bang the blower like it went lean but the plugs looked semi-fat and it was burning eyes on the bottom. Got it right this weekend though........
Old Aug 13, 2006 | 09:47 PM
gun5l1ng3r's Avatar
Can you explain in further detail (about the more load = more hp), maybe going to the molecular level?
Threads like these are great! We are talking about the internal workings of the most powerful IC motors in racing!
Old Aug 15, 2006 | 07:25 PM
A 2000 lb car (same motor) will accelerate slower than a 3000lb car if everything is the same. Nitro produces its own oxygen as it burns, and more oxygen the faster it burns and the more it is compressed. The dynamics of load are still yet not understood, but its a fact we generally accept(im no scientist). Its hard to describe without a graph(and I cant show those...) Tire speed vs. Track vs. Clutch vs. fuel Volume vs. boost vs weather. More clutch=more power=less traction. So lets kill volume. Lower volume & less timing = dead cylinders=lost round. Now let keep the motor happy and take out clutch. Whoops, bye bye motor. Ok now---Lets keep motor happy, giver some clutch. Tire smoke. ****, these test days cost 7,000 a pass, I better get this right. Ok, screw it all,throw away the data. Take a tooth out, pull timing early, make er thirtsy for fuel until 400ft no clutch until 100ft. All in by 700ft. Pray. Twice. 4.52 at 331... Damn, this is EASY!!!
Anyways, other cool stuff.
9000 psi cyl pressures
8 thou on the rods 6 on the mains
12-14 Gals in 5 secs
sometimes 64 seperate injectors
120 gpm pumps
sometimes less than 1:1 af
70 some deg of advance
Old Aug 15, 2006 | 08:43 PM
Xtremes10's Avatar
I would like to see the cam specs on them, im no engine expert, far from it, i just know that somehow they make ~7,000 go 330 MPH in a 1/4 in 4.5 seconds, and are fun as hell to watch, and thats all i need to know, but its fun to read this thread
Old Aug 15, 2006 | 08:51 PM
Brent@LPE's Avatar
on our alchohol car it is much easier to read the egt's than to go after the plug " but I know alot of guys that still do'' we will pick the plugs first and then go to the race pack, double back to the plugs, then adjust valves as procedure... as far as physical limits of a internal combustion engine..... well you know how the story goes it will never go over 100 miles an hour tops....LOL
oh how the times chandge!
Old Aug 16, 2006 | 08:01 AM
bygblok's Avatar
we keep our valves adjusted pretty consistent between rounds unless we break a rocker stand or burn a pushrod. Turns out the pump WAS a tad low on volume but the big problem was a poppet valve that kept sticking and every time we'd pull high gear it would go lean and bang a belt. At $250 a pop for belts it hurts the budget a bit. Got a runner up this past weekend after all went well and would have won the event but had a bonehead moment. Running against a nitrous car "we" do the burnout first(should have let him go first) "we" staged first(another retard move) and got too much heat in the clutch sitting there waiting for him to stage(stupid, stupid, stupid) so the car/driver went red on a .003(aaarrrrgggg) but we split anyway so the weekend was paid for!!! The best part is no parts broke all weekend so hopefully it's a good trend.......... go get me some wood to knock on!!
