Advanced Engineering Tech For the more hardcore LS1TECH residents
what size holes
Old Aug 20, 2006 | 06:01 PM
00454sscamaro's Avatar
Default what size holes
im conteplating making a few parts on my car, and i measured my new slp injectors seems like .550" to about .545" would be about the right size for the injectors bores top and bottom?? seem right?< or can anyone measure there bores or know the size offhand?
im thinking of making fuel rails and intake manifold. i know more trouble then its worth, but im alil short on money and im pretty experienced in fabrication. i think the fuel rails will be easy, just the intake manifold might be alil harder as getting the injector angle right, and everything sized right+even with the rest. i only want to make the fuel rails because i dont want to drill the stock ones and i need to tap into it for my 125 wet shot +the added benifit of bigger rails.
i also have a weird idea on what to make the intake manifold out of, but im not going to share on that untill its done or if i dont go that route. the other option would be aluminum.
