Ls3
I have seen dynoes of Supras making more peak torque than an LS7, but I certainly wouldn't say they have anything resembling a good power curve, let alone a better one than a lower peak torque LS7. Did you just make this up too?
As was stated, with the new SAE procedure, it would be extremely difficult to lie about engine ratings, given there is a third party involved in the procedure. I believe they are allowed to rate the engine anything within a certain percentage of what it dynoed, and I am thinking it is 3%, but I could be wrong. However, if the LS7 did dyno at exactly 505, then the highest they could advertise it at would be 515hp, if my 3% SAE correction factor is indeed correct. Nowhere near 550hp.
look:
The AMG motor doesn't show (x) or (y). Given (x) and (y), it shows (z).
Either way, you're having a fit over 15hp, (since I only used the 520hp number to figure power/weight ratio). I described the two engines as being "about equal," which is true no matter what dyno you go by. (SAE, Katech, etc).
And I'd still bet good money that the LS7 has more power under the curve. But as I said before, I would like to see the graphs side-by-side to confirm this.
How does the AMG give you that? Even given that its true, how does AMG motor + LS7 response to mods = prove LS7 is awesome
LS7 = highly competetive with it in general and definitely beats it on cost and response to mods.
So if hp/l is useless, then let's JUST talk horsepower. The Busa needs/has 163whp to make its current production. To do this with pushrod LS7 technology, it'd need 2.7l. So can you fit a 2.7l engine in the same amount of space that Suzuki fits their compact 1.3l? Hell no, no where close.
A HUGE goal in sportbikes is to maximize power whilst minimalizing displacement (Aka size). That is why hp/l is so important. Suzuki makes the same power our of 1.3l that GM would struggle to make out of 2.7l, and that's with CNC heads, a wild cam, and titanium everything. So you say the pushrod is more compact and blah blah blah, but the specific outputs are so drastically lower that they cannot be smaller for the same power levels since their displacement needs to be OVER DOUBLE that of the OHC.
"And the LS7 definitely beats it in torque and thus the power curve.",
which doesn't make any sense at all. Another assumption on your part.
The fact is that if the standard of making a car move is the one that makes the GM engine look good, then the GM engine IS good.
Here it is again, for anyone who wants to try and find one (yes, I am actually interested because I care about the facts): when comparing two engines of roughly equal horsepower, the one with the higher peak torque output (especially if it is at a lower rpm) has the more robust power curve.
If anyone can show me two engines of roughly equal peak horsepower, where the one with a higher peak torque number at a lower RPM does not have the more robust power curve, I would be interested.
But that is speculation which I will admit. If it turns out that the AMG can gain 125+ horsepower from cam(s), headers, and tuning like the LS7 can, then they'd still be equal on that footing and we'd be left with cost (winner, by a wide margin, would be the LS7). Right now, I honestly think the LS7 will respond better to mods. You can go on the record disagreeing if you like, no skin off my back. Maybe at some point someone will prove one of us right, maybe not. <shrugs>
Looks like we all forgot that zee Germans use METRIC horsepower. 375 kW = 502.8 Horsepower in domestic terms. So the AMG is down 7.2 HP, oh well. I guess someone should tell "the world's most powerful naturally aspirated V8."
'Course that's not SAE horsepower so who the hell knows what it makes anyway. I tried to put up non-SAE numbers for the LS7 to match the AMG's non-SAE numbers but got flamed for that.
Why would I even be interested in seeing the graphs if I considered it 100% proven that the LS7 must have the better curve. I'm still waiting for a counterexample to prove my generalization wrong.
a) proven anything. you just took a lucky guess based on fabricated or distorted information and managed to hit a bull's eye with your eyes closed.
b) proven anything about OHC vs DOHC
Here's an example that shows my generalization to be correct:
Let's see:
"when comparing two engines of roughly equal horsepower,"
check.
"the one with the higher peak torque output (especially if it is at a lower rpm)"
That would be the LS2. Higher peak TQ number at a lower RPM.
"has the more robust power curve."
Well, what do you know? That's the LS2! So there's one example where I'm right. Do you by any chance have an example where I'm wrong? (I'm going to say for naturally aspirated engines, so you don't just throw a graph with a nitrous spike in...) I'm not saying I know it will be right but it makes sense given the math of TQ and HP calculations. I honestly don't know why you're so hostile to it. Perhaps it's because you're the one playing favorites with engines...
You then tried to make the statement you highlighted here to recover some degree of credibility in your arguement. Why should we have to prove your statement right or wrong? You are the one who made it, and you are the only one who has actual said that the generalization is in fact acceptable.
I guess God just blessed him with this superpower where his intuition is always correct or something
Engines with lower specific output have flatter curves because they aren't tune for maximum power at a specific rpm
