Advanced Engineering Tech For the more hardcore LS1TECH residents
Quick push rod length question
Old Sep 19, 2006 | 10:00 PM
ArrestMeRed99Z28's Avatar
Default Quick push rod length question
I did a search and found that the stock cam base circle is .7760 in and the cam i will be running, on XE-R lobes is .7285 in. I also found that the stock pushrod length is 7.385, and I have a set of 7.400 hardened pushrods. So the difference in base circles is .0475 in. So the ideal pushrods would be stock size + difference in base circle which is 7.4325. So my push rods are .0325 in short correct? and is this exceptable? This is my first cam swap and i want to do it myself and do it right! Thanks in advance.
AJ
Old Sep 19, 2006 | 11:53 PM
I realize that this is only 13/400ths of an in and it's probably fine, but better same than sorry so I thought I would ask.
Old Sep 20, 2006 | 06:17 PM
23 views and no answers, for those of you running a cam with a smaller base circle, different gasket thickness, and/or milled heads, what sort of tollerance between ideal and actual push rod size did you use? Any problems? excess noise from the valve train? I know the stiffer springs will make more noise and have heard enough cammed LS1s in person to know what they should sound like, I just don't want to worry about it to much when i put it together.
Old Sep 20, 2006 | 07:19 PM
1989GTA's Avatar
It's a gamble to estimate a pushrod that way. The best way is to purchase an adjustable pushrod checker to get the correct measurement to insure the right geometry. They are cheap enough to purchase.
Old Sep 22, 2006 | 02:26 PM
Nemo02Z's Avatar
I dont know if this is what you are looking for, but I hope it helps....
https://ls1tech.com/forums/generation-iii-internal-engine/327734-cam-guide.html
Go down to the bottom of the thread could have the information you are looking for..
