Advanced Engineering Tech For the more hardcore LS1TECH residents
Hot Honing Gen III Blocks
Old Oct 15, 2006 | 04:40 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Sorry to bring this one back up. An affordable alternative could be the dm performance girdle. They aren't a sponsor, but just type in their name and it should come up. If you plan on running a lot of boost or nitrous on an aluminum block it seems like it would help with everything staying concentric and together. Hardcore Racing's Blue Thunder runs it on it's modified C5R block. I'm not aware of the price of hot honing, but everyone saying it's expensive makes me think it costs a hell of a lot more than a $400 girdle and then $75+ stud kit.
Old Oct 26, 2006 | 08:47 PM
Z06er's Avatar
I believe Katech hot hones their blocks. Call Jason.
Old Oct 28, 2006 | 05:12 PM
cvman's Avatar
Do they still use a torque plate to bore or hone, like the gen 1 engines?
Old Oct 28, 2006 | 06:21 PM
LSPerformance's Avatar
I don't know about "moving around" but the aluminum blocks do expand slightly more. That's why clearances are typically altered vs. the norm (cast iron), that's all thats needed. The hot honing thing has come and gone over the last 20+ years or so, every now and then it gets looked at (as it should) as the hot new thing but has never seemed to make much differance.
Old Oct 29, 2006 | 08:56 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Yes, we are one of the few companies that owns a hot hone. We do not generally hot hone street engines due to cost:benefit ratio.
Old Oct 29, 2006 | 01:42 PM
MadBill's Avatar
If you mean when hot honing, yes: The water jacket has to be sealed off to hot hone, necessitating a plate of some sort, and deck plate honing is pretty well universally accepted, whereas hot honing is smelly, complicated, time-consuming and not always felt to be worth the trouble.
