new valve design.
Just go to the website, I guess, but it still does not explain exactly how it works. Have you done any testing on a spintron to see how the valve acts?
I still don't understand how it is supposed to work.
The website is in the very first post.
This thread sucks and should be deleted. This should be added to the tornado, electric supercharger and ebay computer chip threads.
Sounds more like a plug for this company than someone actually asking to learn more about it.
The benefit was supposed to be that if you have a late IVC, the cylinder pressure would be able to build even at low revs. In effect you always get the perfect amount of cylinder filling even when you run a huge cam.
In theory its a good idea...but the thread on the VWVortex just died and nothing ever came of it, so who knows
FWIW, stock idle speed on a 1999 A4 is 550 rpm, so having a big cam idle at 650 rpm would be fine for oil pressure.
First, two years ago, no that was not Omnivalves. We were making valves two years ago, but to my knowledge we were not online.
But the very first motor we did was a VW.....
As far as making the valve train more complicated, well that is not us!
The guys who are making valves more complicated is ........ Honda (vtec), Ford (VVT) and a dozen other auto makers ......... so you can say what you want but it is not omnivalves that make an engine more complicated. We only change the valve and the ignition timing, and really that is it!
Next, the seat moves, well the seat in the head doesn't move, the "omniring" moves, it is attached to the valve, but if you go to the web site you can see the valve, and the valve OmniRing.
Why is this valve a good idea, well, some people are interested in "dual purpose" use of the LS1, the want all the HP when they peg the throttle but they want to get 25 MPG, and they don't want that rocking idle they and many people want a "sleeper" sounding motor as well. And now, many people want engines that will pass emissions test without hurting the engines performance........... welcome to the future where you can get it all, www.omnivalves.com
Now, people are buying hybrids, why well, that is another matter, but they are buying them. By just changing the intake valves, in any motor, you can get the low end torque that you get from an electric motor in a hybrid.
In January, we are going to have a LS2 engine, 408 ci, with a radical cam. Just built and we are going to Dyno it and video it and post it on the Internet @ www.omnivalves.com
Please keep the questions coming, this is very new technology and it works great and so far we have not seen an obstacle we have not gotten around ........... So, we are excited.
Merry Christmas to you all, form everyone at omnivalves Mike
tieman55, how come no major auto manfacturers are using this valve's technology?
Guys, I say let him develop his stuff and bring it and post it. I don't think *we* have anything to lose by him doing so.
And then put a turbo on it, of course.
Picture this, instead of spending money on a higher stall converter and gears, keep your stock components and just replace the cam and valvesprings. If the product does work as claimed, now you can put in that over the top cam and still have decent low rpm throttle response without the heat and wasted energy of a converter slipping. Perhaps it can be tuned well enough that you can even pass emissions with that cam because the overlap isn't an issue.
As far as major auto manufacturers using it - I'm sure they would want to know it offers them 150,000+ mile durability before they start mass producing such a design. They are the ones who would really stand to benefit from this technology. If OEM's could boost low speed throttle response and keep the same power throughout the rest of the rev's and reduce emissions while increasing economy at idle & low engine speeds, you'd bet they'll jump on it.
Nobody is forcing you to buy this product or saying that your next car will have it. If the stated benfits aren't there, then I'm sure this will just go away. To say it has no merit whatsoever is discounting how the vast majority of cars are operated.
I don't see this design being used in OEM either on gasoline engines. Because of reliability issues the weight of the valve adds to the system. OEM is moving towards lighter valves not heavier valves with "floating seats". Why? Because less weight in the valvetrain means longer spring life, cams won't go flat in 150k+ miles. The mileage OEM vehicles are reaching stems from those and other advancements in engine/drivetrain design. 100k used to be the pinnacle for OEM, now that's tripled. And it's not from adding weight to the moving parts in the engine or oversimplifying current designs. OEM design is improving cylinder head design along with electronics to improve idle, driveability and emissions. No need to reinvent the wheel.
Besides, if this design would be used in OEM guys like me would have to figure a way how to remachine the head to get rid of that crap. Just like low performance heads, SMOG pumps, AIR pumps, heat risers, EGR, skip shift, CAGS, DOD, catalytic converters, 200+ degree thermostats.......I could keep going.
