Advanced Engineering Tech For the more hardcore LS1TECH residents
Re: Octane booster
Old Jan 19, 2007 | 02:32 AM
Ascrap2003's Avatar
Default Re: Octane booster
Is this the nominal composition for 100 octane using 93 octane?
On a stock block, fuel system. W/ Bolt ons and a cam would 100 octane be best for running on 27-28 degrees timing WOT?
Good choice for NOS W/the above config?
10 gallons mix
-1 pint of Tolulene
-1 pint Naptha
-1 5oz bottle of Rosenal lighter fluid (highest Benzene content)
-1 bottle of fuel injection cleaner for trace chemicals
Old Jan 19, 2007 | 05:26 AM
SlickVert's Avatar
I have tried Torco additive a little with good luck.
With stock compression or something under say around 11.5 or less with a good tune, you should not need anything more then 93 octane.
Tune it for the fuel you are going to run. Most LS series engines not making more hp with anything over about 27 degrees of timing.
