Advanced Engineering Tech For the more hardcore LS1TECH residents
Destructive forces inside the rear differential
Old Mar 29, 2007 | 02:33 PM
  #41
trigger1's Avatar
I was running a torsen in a 4.10 geared 7.5 10bolt. Carrier, ring gear, pinion all survived hard launches. My problem was a torsional overload of the axle, initiating at the spline.
Old Mar 29, 2007 | 04:25 PM
  #42
BJM's Avatar
BJM
Originally Posted by thunderdan74
How do you check for carrier perload?
Preload checking for the carrier is the same as for the pinion. You first measure pinion drag at the pinion nut. After inserting the carrier you now have more drag on the pinion nut since you are turning the carrier via the pinion gear. Measure the new total drag. The service manual shows 10-15 lb.in for the pinion alone and 15-28 lb.in (from memory) for the total for used bearings.
If your pinion drag was 15 and your total was 28 and since the gear ratio makes the carrier drag seem much smaller when measure at the pinion, this equates to ~ (28-15 lb.in) * gear ratio (let's use 4:1) = 52 lb.in at the carrier. This is very rough since it assumes the teeth have no drag on each other.
Old Mar 30, 2007 | 12:20 AM
  #43
thunderdan74's Avatar
Now, I see why so many aftermarket rears are so niosey. And I bet after the first launch the part of the bearings held by the pumkin get seated further outward toward the tires, creating more play in the carrier bearings, giving that after launch noise.
I would think it would be a good idea to make note of the initial preload values, go launch it after break-in and re-shim it to get the initial values back. That's assuming it's niose free after it's initial setup, pre launch.
I know it's off topic, referring to my 12 bolt but, What do you guys think?
Old Mar 30, 2007 | 06:32 AM
  #44
billyb's Avatar
Default how's this ????
http://www.lpwracing.com/p_axletubebrace.asp
Old Jun 11, 2007 | 06:23 PM
  #45
squealingtires's Avatar
"Stayin' Alive" TTT for one more trip around...
