Advanced Engineering Tech For the more hardcore LS1TECH residents
Advancing a cam for higher DCR.
Old May 17, 2007 | 10:26 AM
NC98Z's Avatar
Default Advancing a cam for higher DCR.
I have a TSP combo shortblock,heads cam ect. Before installing it I ran dcr calculations on the combo and saw that if i advanced the cam 4 degrees that I could pickup .30. Now everybodys saying that it would make more power under the curve that way but my question is "If you have the bigger intake 237 CCs Stage 2 LS6 heads like I bought shouldn't you try to run the cam straight up so you can take advantage of the higher flow potential of theses heads? If I advance it 4 degrees I would expect the cam to peak earlier.
Old May 18, 2007 | 07:34 PM
NC98Z's Avatar
Damn everybody looks and nobody knows?
Old May 18, 2007 | 09:22 PM
ArcticZ28's Avatar
The cam will peak earlier if you advance it. However, you would optimally like the cam to peak where the flow peaks. It's a trade-off. You can get more area under the curve while possibly sacrificing in the high lift/flow areas, or keep it straight up and gain peak numbers while possibly sacrificing at low lift. How much you will lose/gain in each situation will depend on the cam and heads and would be up to you to figure which is the best situation for your needs.
Old May 18, 2007 | 09:40 PM
67Ranger's Avatar
if you have a way to easily do it, just try it both ways, and see how the motor likes it better.
Old May 19, 2007 | 10:07 AM
WickEdSix98's Avatar
If the cam is on the bigger side of the spectrum I would advance it 2-4*.
Old May 19, 2007 | 10:43 AM
Beast96Z's Avatar
For a N/A combo, I wouldn't advance it anymore than 2 degree's. .3 on DCR isn't going to make a vast diffrence. Using advance to obtain a DCR number isn't the right way to do it.
