Rods
Is that the absolute max they will handle or what they warrant them at?Anyone have made much more hp then the assembly is rated at?
I´m thinkin about how mich the I beam can handle?
Hate to say it but, my current combination has Eagle H-beams at 1076 RWHP. They are being changed out for quality US rods as we speak, even though they look fine. My recomendation would be to use the higher quality rods and bolts when you start hitting the high triple digit HP #'s.
Another thing I have found in the "made in China" budget H-beam & I beam rods is that most of the time you should have them resized and the wrist pins bore sizes checked. The rod housing sizes tend to relax once the caps have been removed and re torqued.
About stock rods,like in the LT1 impala(not pink rods) what is the limiting factor and how high is the limit?
I like the idea of taking the stock bottom endi to the max
