Conserving heat energy
If a sealed shield were put around the exaust manifolds,and the water injected in there, then the steam would flow threw the turbo,condence and run back threw the manifold, then you would be converting the heat loses into boost. In other words you would have a supercharged motor ran off of steam, and the steam would be a result of the heat losses from the motor(combustion). The energy to run the blower would not load the motor. So we call it free energy. The motor would need egt readings of at least 212 degreas(not a problem) to turn the water into steam
Does any one know if this has been done before?
http://www.autoblog.com/2005/12/09/b...-hot-and-goes/
This guy has a similar idea http://www.autoweek.com/apps/pbcs.dl...THISWEEKSISSUE
I think I might have an idea how that 6 stroke engine works,but I'm just gessing. If you inject water in, after the exaust stroke, the heat of the piston/chamber would make steam, after that you have another exaust stroke totalling 6 strokes. Intake(fuel and air), compression, power, exaust,power(steam), exaust. Like I said, this is my gess.
Maximizing exergy has been a research project at Honda. They use water to significantly cool the exhaust and generate steam. They then use that steam to run an alternator, and free up the accessory drive on the engine.
