Duration Vs. Lift on NA Motor
I interpreted 12secSS's post to mean this. If you lift the valve into this chaotic flow regime, there is a good chance the engine won't like it. It does present a challenge to getting more air in. "Fixing the port" is not always possible.
Jon
Jon
I suspect you see that as a problem. What are the alternatives to get more air into the engine?
Jon
Jon
As to how much above the max flow point to lift the valve, that might depend on how much area under the lift curve the engine designer wants. I suggest that the 20-25% you quoted might be high.
Thought experiment:
1) assume that flow maxes at .600 on the flow bench and basically holds there up to .750. This doesn't happen too often.
2) lifting the valve to .750 results in problems with springs and things.
2) what else could you do to keep the valve in the max flow regime for the number of degrees of duration needed to get the air you need and still maintain the IVO and IVC points that are best for the engine? (That's back to my previous post)
Your turn...
Thought experiment:
Your turn...
You may want the cam to come off of the seat slower, but really become aggressive after ~.200 lift?? And then more or less stall out at around .650 or somewhere close.
Off topic a bit because I'm a cam newbie.. With heads aimed at good low-mid lift flow, and a lobe profile with an agressive ramp, would I want to then close the intake valve a little sooner to prevernt reversion? Or is that just a band-aid?
Unfortunately you probably can't do it just with parts from Jegs.
Back in post #5.
