Advanced Engineering Tech For the more hardcore LS1TECH residents
Engine assembly: ring oil
Old Nov 12, 2007 | 07:52 PM
Nitrous fed SS's Avatar
You will get manny different answers, but what ive learned is a little bit of regular motor oil on the rings works fine and ATF on the cylinder walls.
Old Nov 12, 2007 | 08:26 PM
FASTFATBOY's Avatar
Clean the hole with brake cleaner, pour motor oil on a stack of paper towels. Rub the towels in the hole to get a VERY light coat on the walls and install the rings dry.
David
